Belt for record player how to put on - Audio Players & Recorders
  • 3,289 Answers
Please provide manufacturer name and model number.
Posted on Aug 25, 2010
GE 3-5027 portable cassette player/recorder belts
I have a GE Battery operated Cassette Recorder, model no. 3-5025A and the spinals that turn the the cassette will not turn. I believe I need the 3 tiny belts that make it work need to be replaced. The are different sizes, do you know where I can purchase these belts?
Mar 15, 2014 | General Electric Cassette Recorder &...
Clarinette 107 stereo cassette 8 track and record player. stereo works, but record player will not work. how do i find the problem?
I'm assuming you have a belt driven platter. Lift up the rubber mat, turn the platter it to where the motor spindle is, and see if the belt is still on. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 12, 2013 | JVC AL A158BK Turntable
RECORD PLAYER PROBLEMS
Belt is to small or tight--exact belt type on capstan is required--if the old belt works at all try putting it back. Not many DVD players use belts much anymore.
May 02, 2012 | Televison & Video
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Record player
does the plastic mat lift up? if so there should be a hole where it can be slipped back on , if it fell off more than likely you will need to replace it and the table should pop off by lifting it up.
Jan 26, 2008 | Sony PS-LX250H Turntable
 Grubhead
Grubhead
