Question about Zanussi TC7102W Electric Dryer
Only dries at low heat now, although max heat is selected. Yes, the control/heat choice button is in the correct position-hot. Been a fantastic machine for over 7 yrs...Help please...
  • Zanussi Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
MY DRYER DONT START,she make a sound but not start
Hello Friend, thank you for allowing me to assist you!
I understand you are having trouble with your Frigidaire dryer not starting. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, then at this point, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. You dryer may either be experiencing a communication error with the main control or the timer itself may not be operating correctly. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
May 24, 2014 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
I have a CDA ci992 with no instruction manual. I cannot get it to JUST dry. I just need to know which setting to put it on. Any chance you can help? I've tried searching for an instruction manual...
Lisa set the time required on the Drying time control right hand side for high temperature up to 130 mins max and left hand side for low temperature up to 90 mins max. Now set the washer timed dial to the drying emblem (3 vertical wavy lines) next to position 8, then finally you need to push in all 4 control buttons on the left of the thermostat. It should now work according to my wife. Dave
Sep 02, 2011 | CDA CI592 Front Load All-in-One Washer /...
1998 gmc surburban. front blows 82 degrees, rear blows 48 degrees. ambient is 91 degrees. this is with max-recirc-full tilt.the valve for the heater core does not change position no matter where i put the...
Hi John,
Your right with your diagnostics, you have a blend door problem. If your switching to cool air and it is still hot then you also have a heat exchange unit fault, this is the component that changes the water flow from hot to cool by shutting off. If it is not operating correctly this will give you constant hot air no matter where you temperature switch is positioned.
As for the warm air while the engine is cold, sounds like the blend door is still open to atmosphere tempreture and if it is hot outside will pull that hot air into the inside of the vehicle.
Have the heat exchange valve checked, and the only way the check blend door operation is to remove the wiring from the blend doors and have the circuit tested. If the circuit is ok then the blend doors will need to be replaced.
Hope this helps
Jul 24, 2011 | 1998 GMC Suburban
Dishwasher not drying dished with any heat source. Dishes washed in cold water.
Most dishwashers are plumbed to the hot side of the hot water side of the faucet. This should provide hot water for washing the dishes. Perhaps this dishwasher was plumbed to the cold water side by mistake.
Most dishwashers have a heating coil most of the way around under the bottom sliding/rolling dish rack. The heating coil may not be working, which would be consistent with the dishes not drying at the end of the cycle. Possible causes include incorrect setting selected on control console (push buttons) or timer, heating coil disconnected from electrical source at one end or both ends, faulty control circuit inside the timer, faulty wiring between the timer/control circuit and the heating coil, burned or pitted contacts in the control circuit.
May 23, 2011 | Dishwashers
Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
Instructions
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
Feb 24, 2011 | GE Dryers
QuitePower1 Dishwasher won't wash! Fills/empties, but no spray.
Hi Rockwallcond.
Follow the following steps.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
An alternative: Reboot your control • Turn off power to the dishwasher (circuit breaker or wall switch) for
30 seconds; then turn back on.
Oct 10, 2017 | GE 24 in. GLD4100L Free-Standing...
Dryer seems to get too hot even with low heat selected.
Just a thought. Move the drier away from the wall if it close to it and try again. If the air intake is reduced, it will cause the temp. to rise significantly.Also, chech and see if intake andor exhaust is not dirty.
Sep 24, 2009 | Siemens ultraStack WT46E300US Electric...
Dishes with a lot of water left on them.What's the problem? Heating element?
Yes. if this unit is not drying properly, it will be the result of a failed heating element. make sure you are selecting the correct drying method as well. if its on air, it will have a completely different drying time and attribute. if you are selecting the correct assisted heated drying method and, the dishes are not drying, replace the heating element.
***Using the proper rinse agent will increasing the drying performance as well.
Jul 17, 2009 | Frigidaire GLD2445RF Built-in Dishwasher
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
Zanussi TC7102W Electric Dryer Logo
46 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
