Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
What is the valve clearance on a 19.5 briggs off a la105
2 Suggested Answers
  • 376 Answers
SOURCE: what is the valve clearance on a briggs &
.003-.005 intake, .005-.007 exhaust for single cylinder OHV
Posted on Jun 14, 2009
Adjusting valve on a briggs 446677 _e1.__24hp.harde starting
valve clearance should be .010 " inlet hot and .012 exhaust hot
that is .254mm and .304 mm
valve clearance has nothing to do with hard turning over of the engine
if it turns by hand then fix the starter motor , battery leads or battery
the biggest problem with B&S motors is the valve stems which from new tend to stretch reducing the valve clearance when hot thereby making hot starts difficult if not impossible until the motor cooled down
Oct 26, 2017 | Briggs Measuring Tools & Sensors
I have 6.5hp Briggs Intek that backfires through the carb and won't start
4 stroke , check valve clearance, stuck/bent valve
2 stroke --check coil wiring , clearance from flywheel, loose ignition wires to stop switch
Sep 17, 2016 | Briggs Measuring Tools & Sensors
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
Set valve clearance on 21hp briggs and statton
Valve clearances are set by either tappet screws in the lifters or on a lot of small engines, clearances must be set by either cutting out valve seats with a special cutter tool (to DECREASE clearances) or grinding the end of the valve (to INCREASE clearances) and generally are from .008-.010 on intake valves and .010-.012 on exhaust valves. Check engine specs to insure proper clearances.
Sep 24, 2014 | Garden
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Intake valve & exhause clearance
3000 or 4000 is your clearance, get the piston up top dead center make sure piston is to the top of the cylinder rocker arms should be level with each other before you set them
Jun 05, 2010 | Swisher T14560 T - 60" Trailmower with 14...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
252 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
