Question about Olympus Stylus / mju 1050 SW Digital Camera
It says "write protect" when turned on, and can not take a picture, please if you could help
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
it says
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 25, 2010
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Jan 29, 2010 | Fuji Finepix J20 Digital Camera
How can I change the "protected card" so that I can once again take pictures - and how can I keep this from happening again?
Pull your sd card out of the camera... there may be a lock tab along the left side of the card (label facing you and metal tabs up) the lock position is labeled... you can change it with your fingernail... make sure it's unlocked...
Let me know if you're up and running...
k
May 29, 2009 | Fuji FinePix A201 Digital Camera
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
How to take protection off of pictures on camera so I can cancel.
You should do the same process like above to unprotect the images. Trying to delete is wrong.
If this helpful please vote with high rank Marie. Thank you.
Apr 29, 2009 | Sanyo VPC-E760 Digital Camera
Display says "Protected Card"
Yes. Take your card out and on the side there is a switch that slides. Move it up (on the label there is a lock and it's pointing down) Please rate my answer. I hope this helps!
Jan 30, 2009 | Cameras
How do you turn off the camera but with the picture still saved on like if i go outside or something like that
hi there
from what i have found out the camera doesn't have an off button it turns its self off after a period of inactivity. sounds strange i know but it maybe a protection thing if the kids forget to switch off.
the pikkys should be safe this way
hope this helps
beergut707
Oct 13, 2008 | Disney Pix Micro Digital Camera
Deleting Protected Pictures=/
To unprotect images:
- Turn on camera
- Press on PLAY BACK button (wherein you are viewing pictures)
- Press MENU button once
- Scroll to the right until you PROTECT menu tab
- Scroll down to SELECT or ALL PICS
- Highlight ALL PICS
- Press MENU button
* It will be displaying pictures and another submenu
telling you to UNLOCK or LOCK pictures
- Use your zoom switch to change the submenu to UNLOCK
- Once you've seen UNLOCK
- Press MENU button so pictures will be released/unlocked
Those are the steps on how to UNPROTECT pictures
on your A503.
If you'll be having questions, feel free to post it here.
Hope i will be helping you now on these.
Aug 03, 2007 | Samsung Digimax A503 Digital Camera
Olympus Stylus / mju 1050 SW Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
