Question about Kenmore HE2 Plus Front Load Washer
My washer is stuck on F 02 - Kenmore HE2 Plus Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
Error Code P0172
THE 02 sensors is stuck lean. at 0v. the ECU
goes max rich in this case. (compensates) 173 means ECU slammed rich due to 02 reading gross lean.
lots of causes.:
1: a bad 02 , say stuck at 0volts. ( over 100k miles they can to that)
2: exhaust leaks{cracks} near 02. and stuck at 0volts
3: dead or weak, or dirty MAF, causing illegal unmetered air. lean.
4: intake air system has gross air leak.
Jan 29, 2014 | 1999 Toyota RAV4
Never finishes cycle says 02 F
The F02 error code indicates a keypad/user interface failure. This can be caused by a stuck keypad or a failed user interface control board. It can also be caused by a wiring failure or a failed machine control board.
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-02washer dryer problem
F02 means the motor is stuck or jammed, check the motor , tacho and module. For more Hotpoint, Creda and Indesit error codes use this link
Mar 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not spin out after wash. Gives a code
thank you for your response. We solved the problem. There were two of the new softener, he soap pads caught in the pump area. So much for using these ever again. I guess He machines have a problem with stuff getting into this area. My daughter's machine broke because of a pair of panties getting stuck. Wonder how they are getting out of the tub?
My washer show error(f-02
F-02 means that it had a long drain. if the drain exceeds 8 minutes the water valves tuen off. sheck to see if there is a sud error. some of the cuases would be drain pump might be clogged, the drian hose might be kinked, there are foreign objects in the pump.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kepp getting a code f 02 then washer wont do
Open the bottom panel (3 screws on bottom) then you should see a drain clean-out. Unscrew that, there is probably something stuck in there. Have a pan ready to catch the water when you un-screw it. Good luck
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer
no such code f-20..... Found, "f-02", something more then likely something stuck in pump.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite He 4t washer
washer weary, You need to clean the filter on the pump. Remove the bottom panel and the filter will be right in front. 3 #11 torx screws it will pull down and off. Get yourself a bucket to catch the excess water. Unscrew the filter and clean it. Check to see that nothing is in the impeller. The F02 should go away..Catriver.
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
