Question about Sport & Outdoor - Others
I have a reflex timberwolf and tring to figure out the bubb cable size on the sticker it says 39/42.25 and when I look on the list in stores on line they are not marked like that I dont know if that means anything between
3 Suggested Answers
SOURCE: tire sizes no sticker in the door
the stock tires are 215/50 R16.. if u ever need to know for another car. just to walmart or firestones websites and u can but in your car info and they'll tell u stock sizes
Posted on Jun 09, 2009
ftw1952
  • 10319 Answers
SOURCE: 1994 Honda Accord EX 4
they are metric and different sizes were used that year. Get a metric thread sizer at any auto parts store or Sears to determine the correct thread size
Posted on Jul 07, 2011
1999 Yamaha Timberwolf 250 will not turn over. Took it to someone they said it was stator. Replaced stator and spark plug still wont turn. There's no noise anywhere.
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
1994 Yamaha Timberwolf 4x4 Electric Start Problems
no fire 96 timberwolf
http://www.mikekekich.com/92-98%20Timberwolf%202WD%20Service%20Manual.pdf
OEM parts for Yamaha
Yamaha YFB250K Timberwolf Owner Manual
Jan 13, 2017 | Yamaha Motorcycles
Engine number 4BD-211821 need to verify size and year
Hi, Gary this was a tough one I had to dig really deep in my bag of tricks for the answer I am pleased to announce that you are the proud owner of a1996 Yamaha YFB 250cc engine that came out of a 4 wheel off-road vehicle called a Timberwolf for more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
YAMAHA MANUAL STORE
Yamaha Yfb 250fwh 1996 parts lists
Yamaha Timberwolf 2x4 Specifications Off Road com
Feb 11, 2016 | Motorcycles
'92 yamaha timberwolf valve adjustment
Here's the info you're looking for.
1992-1998 Yamaha Timberwolf 2WD and 4WD
Intake: 0.05 - 0.09 mm (0.002 ~ 0.004 in)
Exhaust: 0.11 - 0.15 mm (0.004 ~ 0.006 in)
Jun 20, 2014 | RTO 200cc Full Size Four Wheeler ATV
How to put numbers into speed dial on a Sprint Rumor Reflex
Go to the contacts list. Hit more. Settings. Speed dial. tap a number and select the contct/phone number combo to call.
(Source: I literally just did this on a customers cell phone in best buy mobile)
Apr 07, 2012 | Cell Phones
I recently bought a 1994 honda civic, the intake got stolen and im having a hard time figuring out my car's engine size (number wore off) and i have no clue what kind of intake I should order online....
Hi Hannah, Your engine size should be listed on the emission sticker(on the hood or front radiator support, and its listed within the V.I.N.(vehicle identification number) the 6th digit of the VIN is your engine size. Here is a conversion for that year: "9"=1.6LiterVtec "8"=1.5Liter "6"=1.6LiterVtec "3"=1.6LiterVtec Below are pictures of your VIN and emission sticker.
May 18, 2011 | 1994 Honda Civic
Can't figure out the bolt size for blade shaft. need replacement bolt
Peter, without a complete model number, no one will be able to provide an owner's manual and parts list which would provide the bolt size either. So let's try to figure out the best way to determine a replacement for your fan.
If you can locate the model number of your fan, you can easily obtain a parts list for your fan and the replacement blade retaining bolt.
If that's not possible, the next best thing to do is take the fan with you to a local hardware store (or a big box Home Depot or Lowe's, etc.) and try to find the proper sized bolt in their hardware isle. Many hardware stores have loose bolts that you can try and find the correct thread size and length to fit the fan shaft.
I hope you find this Very Helpful and best regards!
Oct 12, 2009 | Rival Dryers
Need to know size of engine to change the thermstat
Under the hood itself, there should be a sticker. It should be info on Emission standards for the car.
The Emission sticker should list the engine displacement for size. For an example, 1.6L, 1.8L, 2.0L.
Some auto-part store can look up the correct thermostat by the VIN number on the car.
Sep 06, 2009 | 2003 Nissan Sentra
CARBURATOR SIZE
get the VIN number for the bike and ask the local yamaha dealer. (the VIN number has a code for the year in it) what was originally on it when new. and what can fit on it from the aftermarket products.
Mar 10, 2009 | 2003 Yamaha YZ 250
Sport & Outdoor - Others Logo
47 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
