Question about AT&T Blackberry Curve 8300 Smartphone
What does PUK Code mean? Where do I get that code from?
Ipko 049/171/598. What is PUK code?
PUK code means you input your pin lock code wrong too many times.
PUK =Pin UnlocK
Sep 22, 2015 | Cell Phones
My phone is nokia 1100 puk code plz send me the puk
let me start first by telling your the meaning of PUK code. It means "Personal Unblocking Code".
Just has the names personal implies, it means it is a personal code that now one else should know except you. So if I know the code then it means it is no more personal.
What I am trying to say is that the code can only be give to you by your service provider. Your service provider who are the manufacturers of the line you are using are the only ones that has the PUK code to your line.
You can get to your service provider through phone by calling them. Calling your service provider should be toll free.
Your service provider will ask you some questions concerning your line in order to confirm that you are the owner of the line before they give out the PUK code. The questions would be something like; "When did you make the last call on your phone?", "what was the last number you dialed?" etc. These questions varies from one service provider to the other.
Buy now, I believe it is clear how to get your PUK code. If you are not satisfied or you still don't understand, please let me know so that I may help you further....
Regards.
Nov 04, 2011 | Nokia 1100
It is asking for a PUK code after i put in the phone unlock code. Wat is the PUK code
PUK stands for Pin Unblocking Key,this PUK code is used if wrong PIN (Personal Identification Number)code is entered for several try's.It means if you enter PIN for more than 3x,the simcard will be blocked and ask you to enter the PUK code as what is explain above.
Usually this PUK code is on the package together with your simpack when you bought it. in your phone case,you need to enter the PUK code to unblock the PIN so you can access the simcard data's and features,otherwise,if you lost your PUK code, just contact your service provider and ask for your PUK code.
hope it helps...
Jun 11, 2011 | Samsung B3410 Cell Phone
What does puk blocked mean?
Hi.
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
The PUK code is a code associated with the SIM card and not with the phone.
You have only two ways to get rid of the PUK code. Either you replace the SIM card , or you call phone provider that issued the sim cadr (eg. At&T, Virgin, Tmobile , Vodafone, Telecom etc.)
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are linked to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Jun 03, 2011 | Lands Phones
I need the puk code for samsung gravity please
To get your PUK code, if your phone is using a SIM Card, Check the SIM card Pack and you will see your PUK code there. But if you don't have a SIM card pack, you can get the PUK code from your service provider.
Call the customer care line of your service provider using another phone, request for your PUK code and it will be given to you. Note that your service provider will ask you some few questions about your line in order to be sure you are the real owner.
Note that your service provider alone is the only one that can give you your PUK code because it's only your service provider that has it.
May 31, 2011 | Samsung Gravity SGH-T459 Cell Phone
My phone says enter puk code
contact your network provider.. PUK means PIN UNLOCKING KEY.. meaning, The PIN code of your sim card or USIM is locked. or if you still have the case of your simcard or USIM you should able to locate the PUK code. Cheers!
please don't forget to Rate.. Thanks
Apr 02, 2011 | Cell Phones
PUK Blocked? What does that mean?
The PUK & PIN codes are Security Codes that are on the SIM card. PIN( Personal Identification Number ) PUK ( Pin Unlock Key). when the PIN code in entred wrong the SIM automatically Blocks the PIN. to unlock the PIN you need to Enter the PUK. but if you enter the PUK wrong the Entire SIM is Locked.
The PIN Code & the PUK codes are Only Known by your Network Provider. you have to get in touch with them to get the codes. how ever if you have PUK blocked you will have to get a replacement SIM
May 09, 2010 | LG Xenon GR500 Cell Phone
What is PUK code
puk stands for PERSONAL UNBLOCKING KEY which means if an invalid pin code is entered for three times (note that pin code is used to stop unauthorised use of sim) then u ll b asked to enter puk code. If wrong PUK code is entered 10 time thn ur simm ll b blocked permanently it means u can't use tat sim nemore. u can get ur PUK number by calling custemercare of ur operator.. thnx
Oct 21, 2009 | Nokia 1661 Cell Phone
I need a puk code for my nokia 2610 phone
Hi, PUK code is a unique code for each SIM card and will be provided by your service provider.
PUK code is a SIM specific code assigned by your service provider. No way you can guess & enter it. So, when it asks for the PUK code, don’t do anything, get the PUK code from your service provider.
Enter the PUK number in your cell phone and you’ll be able to access your cell phone as before.
Sep 30, 2009 | Nokia N95 Cellular Phone
Puk code
Greetings! When the sim card is asking a PUK code, it means that you have type in the wrong pincode 10 times (depends on sim).
The mobile SIM card comes with a PUK (Personal Unblocking Key) code or PIN
PUK is somewhat protection to your sim card. PUK code is found on the original SIM card or you can ask the Telecom provider for your PUK code.
Hope this helps
Jan 02, 2009 | Lands Phones
AT&T Blackberry Curve 8300 Smartphone Logo
158 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
