Question about Mackie Onyx Firewire Card
I need to place all pan pots at 12:30 to 1:00 to get L = R on a mono (l = R) signal into my Mackis Firewire card. I would like L = R to be the normal DETENT in all pan pots. BTW: with all pan pots at DETENT, L = R on VU LEDs. When at 12:30 to 1:00, the VU LEDs are L > R, but recording data for L is equal to recording data for R. I would like to make permanent change on the Firewire card. I need the schematic for this.
  • Mackie Master
  • 5,603 Answers
The firewire card is all digital and you can't rewire it to bias the pan pots.
You need to do further troubleshooting of this problem before doing any changes.
Wire the L and R lines into the card with a wye connector to guarantee the same signal as a first step. With the pan's at 12 o'clock what do the VU's in the computer show?
There are many possible causes so finding the root cause is important. With the L and R wyed into the inputs, if the VU sensed by the computer is much different (over 1 Db different, then the interface needs work. The problem is likely in the input circuitry and they may have gain pots available. One could damage one side of the inout circuits by improper use or overdriving the input. ALWAYS connect all interconnected electronics to the SAME power source. If power is taken from receptacles at the opposite ends of a room this invites damage due to common mode noise spikes.
From the BTW thing you included, it sounds to me like there is a gain mismatch in the front end of the card... HOWEVER I need the test with the wye cable as you MIGHT have a condition of either a vast difference in the driving impedance between the two sides OR an insidious thing you can't see like a suspesonic feedback that you can't hear but is disturbing the VU indicators.
Venturing a guess as to probable cause, I suspect that the input circuits of one side may be damaged by a static discharge. DO NOT count on the VU led's being accurate as they MAY be totally independent of the conversion hardware.
Another gotcha that can bite is if you are using XLR cables and one has a broken or miswired signal line. Again. the wye cable test will verify this.
Posted on Aug 25, 2010
  • sj_mr_freela Aug 26, 2010
    All power comes from one receptacle. A scope shows nothing funny, Already did the wye experiment: 1220 LED VUs: L=R, Tracktion VUs: L > R by 3 - 6 dB, and more importantly, the digital recording shows the same problem when compared to what the scope sees at the wye input. I believe equal LED VUs indicates (within the binning of each LED) equal signals into the Firewire card. I know the card is all digital, with the exception of the analog front end where I believe (and you correctly observed) " there is a gain mismatch ...." Without a schematic, I can only make an educated guess where this is. The schematic would show the L and R input stages, possible pots, part values, etc. Is it available?
  • Fred Yearian Aug 26, 2010
    Myself, as an electrical engineer, I would trace out enough of the input circuitry. You should have input trimming pots NEAR the input connectors (if they exist at all), possibly right behind the input op amps.
    The manufacturers really are stingy with schematics and I have not found one for this unit yet.
    If you are using XLR connectors OR TRS input, trace AND check the continuity of those. Expect the two balanced lines to go to an op amp first. You should find the layout is RELATIVELY symetrical so you can compare sides. Verify with the ohmeter continuity to the input resistor network.
    I suspect that one side of a balanced line MIGHT not be connected which would result in a 6 Db difference. This could be bad solder at the connector or scratched or cracked circuit board.
    ANOTHER possibilty is that MOST of these circuits have small capacitors for noise suppression to ground from each balanced line wire AND these often get shorted due to static. This results in a 6 Db loss on input.
    Google op amps for typical circuits.
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Marshall Amp Quit
According to the schematic, once the signal is initially amplified (also where the LED shows signal), the audio is sent to the send/return jacks (shown on pg3-C7). A quick test to see if audio exists at the insert point will require an insert cable. An insert cable can be a balanced 1/4" cable which splits out to two mono 1/4" connectors or a pair of RCA's. Connect one of the insert outputs to a console (if 1/4" cable) or a tape loop on a home stereo receiver (if send cable splits out to RCA's) and see if you've got sound when playing your guitar (with LED on the Marshall showing signal). If no sound, go to (A) below. If you have sound, go to (B) below.
(A) Ten pin connector labelled CON2 (shown on pg5-B1). Make sure connector is tightly seated and that the pins on the jack and the female connectors in the plug are clean and that good contact is being made.
(B) Twelve pin connector labelled CON1 (shown on pg5-B4). This is the DFX board - make sure this is tight and well seated.
According to the schematic there are voltages seen at several of the connection points previously mentioned. If you have a multimeter and are qualified and careful - check to make sure the voltages are present as shown.
If you're not qualified - meaning you have little or no experience - STOP and refer this repair to a qualified bench tech. They get paid to keep the magic smoke inside the amplifier. You may end up damaging things worse or even beyond repair or even damaging yourself.
Nov 12, 2013 | Marshall Amplification Marshall MG250DFX...
Have a fender squier 4 and wondering if you plug one side can you get full mano output?
What do you mean by "Plug one side"? Your guitar is mono....you plug into the channel with a mono signal cable....as long as you're panned to center on your channel strip, you would have full mono sound out...ie sound equally from both speakers. Usually you would be running your board in mono anyway.
Aug 17, 2012 | Fender Squier 4-channel Travel PA...
Stereo channels do not collapse to mono.
Unfortunately, behringer is not helpful in most cases.
I suggest selling the unit and buying a better product, like mackie.
Mar 31, 2017 | Behringer Europower PMP1680S 1600-Watt...
My Yamaha mm6 doesn't work stereo, just mono. when u put 2 cables it works from right channel, but if u put to the left channel, works from the left. I don't get it.
There is probably a setting that is wrong. The left channel is the default for mono operation. Look in your user manual regarding "PAN" which controls the output going side to side. You MAY be "panned" clear to the right. When you plug into the left, it is the default so in spite of being panned right, they would send signal to the left IF nothing is plugged into right.
Jun 14, 2011 | Yamaha MM6 61Key Synthesizer Keyboard
I've told my Frontman 65r has a real reverb tank (accutronics). But it's almost imperceptible, even with the reverb knob at 10. Is that normal? Also, mid scoop for the drive channel and treble/bass for the...
The reverb should be quite strong. I would first look at the reverb volume pot R42 which is a 50K pot. I would also check the voltages on the test points near U4 (TLO-72 op amp tp13 and tp14) which amplifies the signal coming out of the box. It is possible the box has low power levels as well.
The problem is going to be around that section of the board if it isn't a dirty or dead(ish) pot.
The reverb should be noticeable enough to be annoying ;-]
Mar 18, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
How can I connect my mackie mixer 1202-vlz3 to my mac mini
use the xlr (3 prong) main left and right outputs of the board. get xlr to 1/4 inch cables. one end will be 3 prong, to plug into the mixer, then the other end will be a mono 1/4 inch plug, like a big headphone plug. Then you have to get a dual mono 1/4 inch to stereo 1/8 inch adapter and plug it noto the line in. if there is no lone in, but a microphone jack instead, you will get a mono signal instead of a stereo signal. in this case, just use 1 channel of the mixer, instead of both of the stereo outs, and use a single mono 1/4 inch to mono 1/8 inch adapter.
the xlr to 1/4 inch cables can be purchased at a music store. the 1/4 inch to 1/8 inch adapters will probably need to be purchased at radio shack.
Nov 03, 2010 | Mackie 1202vlz3 12 Channel Mixer
Hi I have a mackie sr series 24.4.2.b bus miximg console in for repair,most of it is working except that the right channel output is misssing on on sub outputs 1 and 5 and 3 and 7,i do not think its...
Remember that the subs are each MONO outputs. They do not have stereo outs. They can be used as pairs like 1-2 for stereo and those should PAN with the pan control at each channel assigned to a sub.
For mono's, the left channel is the one used.
Refer to the signal flow diagram for the Mackie mixers to analyze this. It probably is on page 28 of your manual.
For the subs, you can pan AT THE CHANNELS ASSIGNED between for instance sub1 and sub2. Note these work together as odds and evens.
Jul 14, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Sep 27, 2009 | Boss Micro BR Digital Recorder
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
Mackie Onyx Firewire Card Logo
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
