Question about GE Profile JGS968 Gas Kitchen Range
GE Profile JGS968 gas range. Top burners work fine. But neither the bake nor the broil burners are working. Both igniters glow bright orange but no gas is flowing. Could this be a valve or thermostat problem?
  • rod_barbee Aug 25, 2010
    It's not any clock setting either. Like I said, the igniters glow but no gas is flowing to ignite the burners. Also, the internal oven fan comes on as normal.
    The clock is fine, there is no time-delay set.
    Oven fan comes on, both igniters glow (broil and bake--not at the same time, of course). Just no gas getting to burners.
  • 857 Answers
AS per you explanation of the problem
If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Posted on Aug 26, 2010
    Brigadier General:
  • 3,513 Answers
Hi
Please check the link bellow regarding your query…
http://www.repairclinic.com/Range-Stove-Oven-Troubleshooting#Itwontbakeorbroil_electric
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 25, 2010
Bake feature will not work
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Apr 18, 2010 | GE Profile JGS968 Gas Kitchen Range
GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
I have a JGBP30 gas range and the oven does not. Someone checked it and said the main control is bad. Is there a manuel that I could get or is there any way I could check it, before ordering a new...
Does the oven ignitor "glow" when turned on but no flame appears? does this model have an actual broil burner ? or does it just have a broil drawer at the bottom ? If it has a broil burner up top of the oven, does it ignite ? It could be the clock/timer, but rarely. If the "bake" ignitor glows, but the burner doesn't ignite, or ignites slowly and/or a "sputtering" flame, replacing the bake ignitor should solve the problem.
good luck
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Aug 01, 2009 | GE Profile JGS968 Gas Kitchen Range
GE jgs968 range seems to be working fine except the oven, broiler works fine
Please note that sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking. That's why it's always a good idea to swap ignitors to verify you have a faulty one.
If you want to see what the part is for your oven, go to searspartsdirect.com and enter in your model number to view the line drawing for your oven along with the parts list.
Hope that helps and best regards!
Jun 07, 2009 | GE Profile JGS968 Gas Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Jan 28, 2009 | GE Profile JGS968 Gas Kitchen Range
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile JGS968 Gas Kitchen Range Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
