The heating demand is off.Do not know how to put it back on
    Problem Solver:
  • 28 Answers
Turn the switch on your thermostat to heat and the fan to auto then make sure the thermostat is turned high enough to call for heat
Posted on Aug 26, 2010
The dealership put a new computer in the engine of my 2001 Maxima, and it still doesn't start. They can't figure it out. A friend said to bring it to a high performance place with better equipment?
Since the NEW computer changed NOTHING, demand that they PUT THE OLD COMPUTER BACK IN, AT NO CHARGE! Then take it somewhere where they KNOW what they are doing!
May 11, 2017 | Cars & Trucks
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
My window air conditioner keeps turning off. I reset the surge protector and it goes back on and then shuts off
remove the surge protector it over heating . your unit is probley experencing a low voltage condition due to total demand due to the heat wave
Jul 22, 2011 | Heating & Cooling
95 altima idles rough then when i turn on the a/c it will idle fine
When ever your using fans, heat or air It requires more power to operated through system, more demand on engine. If has been idling rough, the a/c has nothing to do with the rough idle problem so much, as it just puts more demand on engine, to lower idle, I would check have fuel injection cleaned, possibly air filter and oxygen sensor replaced. Let me know, if this has helped. Thanks mike from fixya.com
Jun 10, 2011 | 1995 Nissan Altima
Speakers are crackling while a movie is playing, which means for about ten minutes and then suddenly turns off with the power push light flashing. I tried unplug all speakers and all connection but...
so when all speaker wires removed and receiver on it still will go into protect mode and shut down? if so then it has to be heat is to great where you have your receiver placed. move your receiver from heat area and try to see if it keeps happening. another thing is you haven't stated if speakers are right for your system and or if ohm of speakers are right for your system. if the speakers are a lower ohm then what your system requires then you will put more demands on your system and cause more demand on receiver and create more heat in amp and it will shut down especially faster when you have it close to heat source. also speakers crackling is also a sign of too small of speaker gauge wire used which can also put demand on receiver and cause same problems.
Jan 06, 2011 | Audio Players & Recorders
Wiring a thermostat
Comm should be the common terminal/wire
Satisfied means that the unit is no longer calling for heat because the thermostats setting has been "satisfied" and has shut the unit off until the room is cooler and it is then "damanding" operation. This should bring the unit on. (when the thermostat is in "demand")
Dec 10, 2008 | Electrical Supplies
Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Nov 24, 2008 | Honeywell Programmable Thermostat Heater
On-Demand Water Heater
An on-demand, or tankless, water heater is a system for heating water as it passes through the pipes, usually very near the point of use. Traditional tank water heaters bring the water to approximately 140 degrees Fahrenheit (60 C), in order to ensure the water supply lasts long after the heater turns off. Since this is obviously far too hot to be pumped out of a shower of faucet, cold water is added to the mix in the pipes. Coupled with the loss of thermal energy over time, the average tank heater has an efficiency of approximately 80%. On-demand water heaters have a number of advantages over their tank-using counterparts. While tanks often degrade over time and begin leaking, the apparatus used in an on-demand water heater is much less susceptible to the burdens of age, and will often outlive the house they're installed in. The amount of energy used is a fraction of that used in a tank water heater, due to increased efficiency and a much smaller window during which a heating source is in use. While tank hot water heaters can, and often do, run out of hot water after a number of showers, on-demand heaters provide a never-ending supply of hot water, ensuring that warm water is always available when needed. A tankless water heater can cost between $500 and $1500, and they most commonly use either electric or natural gas energy to heat the water. Most mid-sized households report an energy savings of approximately 25-45% for a gas or propane heater, and up to 50% with an electric heater, over using traditional tank heaters. Water is usually set to a maximum temperature of 120 degrees Fahrenheit (49 C), though many heaters allow for custom setting of the maximum temperature via remote control. Outflow rates range from 8-14 gallons (30-53 litres) per minute. Installation for most tankless water heaters is incredibly easy, involving simple plumbing. In the case of electric heaters, all that is required for a fuel source is to plug the heater into an outlet and begin heating your water. Some modern on-demand water heaters can incorporate a solar preheating system. This system uses a traditional solar heating system and tank to bring the water nearer to the desired temperature, saving substantial energy use in the final on-demand heating. A solar preheating system costs between $500 and $800.
Aug 27, 2008 | Stiebel Eltron CK20E Electric Tankless...
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
