Question about Frigidaire Affinity AEQ6000WH Dryer
I try to turn my dryer on, and it has a "dr" error on the timer??? I would think that means door, but the door is shut??
  • 1,531 Answers
Press and hold select and cancel buttons together for six seconds this will reset the board.there is also a chance that the door switch is bad and not seeing the door is shut
Posted on Aug 25, 2010
Frigidaire gas dryer with error code dr.
Dr or DR is a generic door error code. Either the door is not shut properly, door is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 18, 2012 | Refrigerators
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
44082 is the model #
he code "dr" means the control doesn't see the door switch being closed.This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced.
Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem.
The switch can be obtained from the following link: Sears PartsDirect . Remember to unplug the washer first before attempting to change the switch.
The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
I hope this information helps you resolve this problem but submit another question with any additional details for further assistance.
Helpful attachments:
The code "dr" means the control doesn't see the door switch being closed. This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced. Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem. The switch can be obtained from the following link: [Sears PartsDirect |www.searspartsdirect.com] . Remember to unplug the washer first before attempting to change the switch. The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
Apr 15, 2010 | Kenmore 43042 Front Load Washer
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Buzzer won't shut off. only when door is left open
could be a number of things, but you may want to test with an ohmmeter if you have one.
It sounds like your timer needs to be replaced. If the buzzer is not shutting off, the timer may not be turning to the off position. It may be really slow our out of wack, not letting the dryer completely dry. It also could be an error with the dryer's control module (kind of like a computer for the dryer)
I also recommend playing around with door switch, it to may be faulty. If the dryer does work with door closed, it is unlikely to be the door switch. You will have to test timer and door switch with ohmmeter or voltmeter to determine that the voltage current is constant and not speratic or shorting out.
May 18, 2009 | Kenmore Dryers
Code dr keeps popping up even if the door is shut and the dryer will not turn on
It means that the door switch is making a bad connection. You should look around near the door switch for loose parts or wires. If everything seems tight, perhaps replace the door switch
May 06, 2009 | Frigidaire FGQ1442ES Gas Dryer
Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer doesnt shut off
Does it appear that the timer is advancing? Try a new timer if not.
Sep 09, 2007 | Dryers
Frigidaire Affinity AEQ6000WH Dryer Logo
79 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
