Question about Makita 12 Volt Cordless Drill/Driver Kit
How to dismantle makita drill 6011d - Makita 12 Volt Cordless Drill/Driver Kit
  • 42 Answers
SOURCE: makita cordless drill 6011D
It sounds as if the brushes may be bad / burnt / chipped. If you fire up the drill in a dimly lit area you will likely see sparks inside the unit. The smell is the ozone that the sparking creates.
I have an 18 volt DeWalt that sparks and smells like something inside is cooking if I use it. I use that drill occasionally and every time I do I think that sooner or later it is going to give up the ghost permanently.
Now, if I had a 120 volt plug-in-the-wall outlet drill that was doing that I'd deep six the drill and get a new one. They are cheap enough and you really don't want to be dealing with sparking with an item that could short circuit and cause some real harm or damage..
You could get it repaired, but that wouldn't be cost effective. Take a wire cutters, cut off the plug from the wire and discard.
The one thing I would not do with the drill is sell it at a yard sale. It just wouldn't very honest to do that.
good luck.
Posted on May 16, 2009
darjr
  • 378 Answers
SOURCE: How to Replace the trigger switch on Makita 6011d
Unscrew the cover then remove the triger sw then replace it.
Posted on Jun 08, 2009
smjdragonfly
  • 79 Answers
SOURCE: My trigger switch for Makita model 6011d stopped
Yes, you need to take the chuck and the collar off. Not bad though. Make sure you put the collar back on correctly. I think the switches on those have to be soldered, if I remember that model correctly. Be careful. You could ruin the main switch if you accidentally cross the circuit with the small resistor to other terminals. Lemme know. Please rate me.
Posted on Jun 18, 2009
Testimonial: "You're correct. It cost $70 to fix, but I think it was worth it. Thanks"
efs_perpends
  • 1996 Answers
SOURCE: 6011D drill/driver won't run with battery cover
Could be the contacts where the battery seats inside the handle are worn or the battery itself has bad contacts. You can try polishing the battery terminals with a pencil eraser to remove oxidation, etc. If you jiggle the on/off switch around does that have any effect? And make sure the battery clip is keeping the battery fully engaged...
See here for an exploded parts view of your drill. If you're comfortable opening it up, you could try bending the battery contacts so they have more tension on them and see if that works. If the contacts work well, the switch could be failing...
You may just need to have it serviced somewhere....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 05, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a MAKITA MODEL
in the tip section there are detailed instructions on how to remove a drill chuck.
Posted on Sep 22, 2011
How do I take apart a makita6011d cordless drill
Here is a site with a break down and the parts list Makita 6011D Cordless Drill Parts
Have a Good Day
Nov 15, 2014 | Drills
Why does my Makita 6011D cordless drill not work when my charged battery in installed? The battery does work on my Makita saw so I know it is not the battery.
Look inside where the Battery terminals connect.
THey are flat metal springs inside the drills Battery hole.
Make sure the are not compressed down causing them not to touch the battery terminals of the battery.
ALso check the Brushes on the drills motor they may need replacing...
Selvol
Jul 06, 2014 | Makita 6011DW Battery 1500mAh, 12V, Ni-Cd
I have a MAKITA MODEL 6011D I got the screw on the chuck out, its a reverse threaded screw. How does the chuck come off?
Sep 21, 2011 | Makita Drills
I have a 6011d cordless Iam trying to remove the chuck appearantly someone has tried removing and the allen capscrew is damaged . Would anyone have a solution for removing the screw?
You could try a screw extractor, the only problem is this may likely be a reverse threaded screw (probably why it was damaged in the first place) Try and jam(gently sort of) in a bigger hex wrench If it is beyond a hex wrench you could try to drill it out with a slightly bigger bit then the hex socket, but only drill down a little bit further then the socket hole originally was. Don't drill into the shaft of the screw. then try to screw a sheet metal screw into the hole. You want it to be big enough so it binds to the sides of the hole. Then as you tighten the screw you may loosen the hex screw.
Jan 02, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
How do you get the chuck and change ring off of a 6011D
Chuck: Change ring: you have to remove all screws from handle and chassis.
Juraj
Dec 10, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How to dismantle a makita HP electrical hammer drill, want to replace the brushes
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Sep 13, 2010 | Makita HP1620F Electric Hammer Drills
My trigger switch for Makita model 6011d stopped working. Although I removed all the screws, the handle cover doesn't come off. Does the drill chuck need to be removed and if so, how is this done? thank...
Jun 08, 2009 | Makita Drills
Makita cordless drill 6011D
Here is the schematic for you: http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/6011D
If it is running just fine and meets your needs I would just keep on using it.
May 16, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Makita 12 Volt Cordless Drill/Driver Kit Logo
135 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
