Question about Poulan "Poulan" Push Mower
It will start for few seconds after i prime it, but it wont run.
  • 183 Answers
Something is not allowing fuel to flow thru the carburetor. The usual suspect is water in the gasoline. Sometimes there can be some other debris causing the blockage. The needed repair is the same in both cases. The carb and fuel tank must be cleaned. If the mower is more than a year old, I also recommend replacing any rubber parts in the carb.
Posted on Aug 25, 2010
Why wontsmart carb engine start if primed runs for few seconds
dirt or water in the carby jets
priming it just puts a squirt of fuel in the manifold and that is the initial start run
Jun 19, 2015 | Garden
Why doesnt electricity to my fuel pump the fuel pump fuse doesnt have electricity
wont have constant power unless its running ,,,, when you first turn on ign it cuts in for a few seconds to prime the fuel system and then only runs constantly when engine starts,,, if its not doing this it could be a faulty relay or a crank sensor
Nov 22, 2013 | 1998 Cadillac Catera
Starts but wont stay running
it will not run because the key has a chip in it,and is a alarm box that runs it.
Dec 16, 2012 | 1996 Pontiac Grand Prix
WE OWN 92 CAMARO RS 25TH EDITION IT WONT START ITS GOT FIRE POWER AND SPARK SO NOW WHAT ITS DRIVE ME CRAZY WHAT TO DO. WE CHECK THE SPARK PLUG AND BATTERY AND ITS GOT GAS BUT IT WONT START WHAT DO U THINK...
92 Camaro, V8 5.7 multi port, new pump, good preasure. runs when primed, wont start without prime. After sitting a few minutes, engine fires wont start. How to check EGR Valve and what does it do?
Feb 15, 2011 | 1992 Chevrolet Camaro
Wont start unless manually primed
Turn the ignition key to the ON position without starting the engine
You should hear the fuel pump priming for about a few seconds then shutting itself off.
If not hear replace the engine oil pressure switch
The 3rd wire to that switch is the pumps prime switch lead.
When the engines oil pressure is reached the computer will shut that circuit off and turn on the fuel pump relay
If you hear the pump prime the relay maybe at fault instead
Jan 19, 2011 | Chevrolet 1500 Cars & Trucks
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
Where is my fuel pump at? on a 1995 chevy camero 3.4 yes ran the car out of gas put so in wont start now what should i do first
Your fuel pump is in the tank. Turn on the ignition, and listen if you can hear the pump run in the tank. It will only run a few seconds if the engine is not running. You can repeat this several times to prime the fuel injection.
Feb 11, 2010 | 1995 Chevrolet Camaro
My 1994 honda civic dx died while i was driveing it and now it wont start back up the engine turns over but it still wont start
Fuel pump could be issue. Check for spark from plugs and see if you can here you fuel pump prime when you put the ignititon from off to run but not start. Should hum for a few seconds and quit.
Jan 14, 2010 | 1994 Honda Civic
How to prime intake, car was ran completely out of gas.
turn key to run position for 3or4 seconds and off for 3 or 4 seconds , do this about three times and it should prime and start , may run ugly for a few minutes after starting
Nov 25, 2009 | 1986 Nissan 300ZX
Runs for a few seconds then stops
there are two screws on the carburator one is for air other for gas .that need ajusment
Dec 30, 2008 | Husqvarna Chain Saw 20" Bar
Poulan "Poulan" Push Mower Logo
63 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
