Question about Samsung Digimax S730 Digital Camera
Battery keep going down do i need a charger - Samsung Digimax S730 Digital Camera
    Genius:
  • 1,234 Answers
Your Bettery Is Old
You Need To change It
Posted on Aug 25, 2010
My kindle fire hdx 7 running lollipop 5.1 is charging but not keeping the power
Hi try another charger could B an intermittent fault with charger.if it's not the charger it could B a fault in the tablets charging circuit or a faulty.,,,, battery good luck
Mar 06, 2016 | Amazon Kindle Fire HDX 7
Can I charge ev warrior with standard battery charger?
Yes, But. 2 pack so 6volt each, I will assume standard lead acid batteries as the is common, and that is what the pic shows. depends on what you call standard charger, I would not do it with my 40 year old standard charger, although at a push, it will still charge them, but need to keep a check on them, later chargers, monitor the battery voltage, and adjust output to suit. All chargers work the same way, so basically yes, but keep a check on them, not running to hot etc. check voltage if you can. But they all work the same way, just later cells are used to the controlled cct of later chargers. especially with them being so called sealed, they still let gas escape, via a pin hole, If they get hot, to much gas, going out, reduces the effiency of the electrolyte, so will reduce the life, BUT as long as you keep checking them and stop if they get hot no problem, they will get warm anyway.
Jul 29, 2014 | UPG 12V 18AH Electric Bicycle Co EV...
Need to purchase a battery charger, what type do you recommend?
It really depends on what you are going to use it for. I use a small charger when I just want to maintain a battery. I use mine also for keeping the battery up while I am performing computer diagnostics on a vehicle without the engine running.
The charger I use is a DSR Pro Series Model PSC 12500A It is fully automatic and has a 125 Amp boost. It is very compact and easy to use. It has LED's that tell you the condition of your battery, the charging rate, etc.
I purchased mine from Matco Tools (Matco part number MIC1200) It is available through many local parts suppliers as well as online automotive parts and equipment suppliers.
Jan 15, 2011 | 2003 Nissan 350Z
My Samsung reclaim keeps randomly powering down. Why is it doing this and how can i stop it?
Please check your battery for wear down. Otherwise keep your power adapter/ charger On and turn on your phone ( just to see what will going on). If still problem your phone was damaged internally and need to repair at shop
Dec 26, 2010 | Cell Phones
Chair not holding charge
It's your batteries. If they charge at all, your charger is okay, if not at all, new charger is in order.
Don't run your batteries down past half-disharge if you can avoid it. Charge daily or even more often if you are a road warrior, but try to keep them topped off. They don't have a memory.
Jan 22, 2010 | Golden Technologies Compass Electric...
Phone dies quickly after charging
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but... Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever). Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies. If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current. This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different. Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities. A.
Jul 25, 2007 | Motorola Mobility RAZR V3
Samsung Digimax S730 Digital Camera Logo
15 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
