Question about Anne Klein 10 7977MPTT
How do I take the extra links out ? It has little pins in it
  • 831 Answers
Thank you for contacting FixYa.<br /> You can follow directions for your band at this link:<br /> <a rel='nofollow' href="http://www.webwatches.co.uk/how_to.htm" target="_blank">http://www.webwatches.co.uk/how_to.htm</a>
Posted on Aug 25, 2010
I need extra links for the Nixon 42-20 crystal bezel chrono. The watch is too small.
I have looked at the Nixon site and it says that spare links are provided in the bottom of the box, see below.
Do you still have the presentation box?
"The compartment at the bottom rear of the watch stand can be opened and closed, and it contains the user manual and extra links and pins."
Apr 07, 2011 | Nixon Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Ive had my Seiko automatic titanium scuba 200m about 3 years when i got it, i had it sized down by taking out 3 links which the store gave me back and 3 pins that go with , ive put on a few pounds maxed...
Thanks for contacting FixYa.
Seiko normally will send out up to 5 extra links on new watches. I am not sure on watches that are 3 years old but you will need to contact Seiko on this one. MAYBE a watchmaker locally will have some extra peices that will work too.
You can contact Seiko here:
http://www.seikousa.com/support/customer/northamerica.html
Best regards.
Jewel
Aug 30, 2010 | Seiko Diver's Watch
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    My son received a merona watch and we cannot figure out how to remove the extra links to make it so it will fit him. Can someone help?
    i have a merona watch too. i found wire brads in my garage, then pounded out the pins partway. then i put the end of the pin that was sticking out into a vice grip and pulled the pins out. then remove the link, and use a small hammer to put it back in place. it might take a while, but it works.
    Dec 26, 2009 | Watches
    Is there any way to adjust the band without a special tool?
    Use a sturdy pin or thumbtack to push out the pin from the little hole on the link.
    Make sure to examine the watch and which links have pins. Some watches are designed to have a row of removable links with pins.
    Remove one end of the band from the actual watch itself. Then remove links as you see necessary.
    You may need to use something a little stout like a butterknife to tap the pins out from the links.
    The pin on the watch itself has spring loaded tips, push them in and it should release the watch from the band.
    Oct 04, 2009 | Festina 16177 3 Watch
    How do i use the watch band link tool i just got with no instruct
    Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
    Do not forget to rate, please.
    Feb 11, 2009 | Rolex Datejust SS
    Link pins for a womens Fossil watch
    The only place you can get them is at a watchrepair. Sometimes I have found wierd sized link holes and have had to make my own pins. I just take a small nail and file it to the size I need. If you have a dremmil tool with a sandpaper attachment it is so much easier! Take a nail that is a little bit longer than the link is and sand down in a slow graduating cone shape, make sure to top of the nail is a little bit wider than the hole on the top of the link. Once you have that , put the smaller end in the link , line up the other link so that the pin goes into both links , and then tap it in. The pin should go into the bottom of the links. It might be good to do this on a piece of wood so that if the pin goes a little through the bottom, you don't damage anything. Try to make the pin as tight as you can, and than file (or dremmil) the top and bottom to the links size. If you still have problems please let me know, and maybe I can help you further. Good luck!!!!!
    Oct 27, 2008 | Fossil Watches
    Trying to shorten the band on a fossil watch. removable links have arrows which point outward on both sides of the link.
    You need a small, (smaller than the pin hole) punch to force the pins out of the band. Since the arrows point in both directions you can push from either direction. Push enough of the pin out to be able to grasp it with a pair of small pliers and remove it. Do that on both sides of the link, replace the extra with a small hammer and you're done.
    Sarvadrk
    Jun 18, 2008 | Fossil Watches
    Remove the extra links in a luminox 3204 watch band
    It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
    May 12, 2008 | Luminox Navy Seal Dive 3204 Wrist Watch
    Anne Klein 10 7977MPTT Logo
    Top Anne Klein Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
