Question about ViewSonic VA1912wb 19" LCD Monitor
Viewsonic VE910b LCD monitor went blank no light
Hi i have two LCD monitors and they both went blank, no light LED at all.
Are these fixable, they worked fine for about one year +.
  • 2 more comments
  • gcroland Jul 30, 2008
    I also have 2 VE901b viewsonic LCD monitors, both did the same thing first went just after a year and the other lasted 2 years. they run perfectly fine and without any warning they go blank trying to come back on. you will see a flicker of the screen for a tenth of a second then black for a couple seconds. power light is on when thescreen flickers on and off when screen is black. would like to be able to fix if possible just need help to determine what part i need to replace I suspect the power supply or inverter
  • hudef Aug 29, 2008
    Mine always stays black. The only sign of life is when I first plug it in the little green light goes on for a second and then nothing. The manufacturer gave it a 3 year warranty. Does anyone know if walmart sold this unit? If so you can always take it back there for credit, even without a receipt.
  • Anonymous Sep 29, 2008
    Green LED comes one for 2 seconds when you first plug in the monitor to power but then there is nothing and the LED goes off.
  • Anonymous Nov 04, 2008
    Same problems as above VE910b
sandrew
  • 2961 Answers
SOURCE: LCD Monitor turns off or goes blank after a couple of seconds being on
An all too common problem with lcd's, you would think they would be more reliable after being on the market for years, alas they are not. See if it does the same thing on a friends PC if you are able; if so the you will know the lcd is faulty.
Posted on Nov 12, 2006
Riziel
  • 116 Answers
SOURCE: LCD Monitor has no video
Sounds your monitor has either blown a backlight or the inverter board is bad. Either way they can both be replaced, but tracking down the parts will be a bit difficult. But your LCD Monitor is in trouble! Sorry!
Posted on Nov 26, 2007
SOURCE: Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
Posted on May 06, 2008
SOURCE: viewsonic vp930b-3
I just had the same thing, blinking green led. I changed the 2 1000uF 16v capacitors on the power board and back in business!
Posted on Aug 22, 2008
  • 152 Answers
SOURCE: How do you remove the outer case on Viewsonic VG930M-3 LCD
kauffman014, As far as opening the monitor up you may want to visit YOUTUBE and search for lcd monitor repair/ disassembling monitor/ or something like that. I did see a 9-11 min video there that was fairly good on un-snapping the rear cover from the front bezel of what I think was a DELL unit. Also visit electronicrepairguide.com run by a jestine yong. don't pay any attention to his ad to purchase repair course in lcd/fpd servicing!! only look at the pic's of the insides of lcd monitors and the power supply boards/inverter boards. On gateway's, and dell monitors the pedestal must be unscrewed from the rear cover first. The pedestal is really screwed down to the steel FPD chassis that covers the circuit boards and provides a ridgid mounting surface for the unit as a whole. Work on a flat surface with screen facing down on a blanket or lots of newspaper to prevent maring of the FPD!
There should be some phillips screws that fasten the steel shield to the left/right sides of the FPD frame. Once you get down to looking at the Switch-Mode-Power-Supply (smps) board look for large filter capacitors (electrolytic polarized aluminum can) that have the tops of them bulging upward as compared to normal ones that are flat. You will also need to inspect the bottom (solder side) of the board where all the leads of the components from the top side are soldered. You are looking for very thin hairline 'thermal' and or 'vibration' circular FRACTURES around the leads of the larger and bulkier (heavy) components. Yeah...use a big magnifying glass or better yet a 10x or 20x inspection microscope. One last thing, I highly recomend taking digital pic's as you disassemble the unit so it can be put together again without leftover parts. hope this info helps you out. Get back to me if you find out anything. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Posted on Mar 28, 2009
I have monitor view sonic(VE910b), suddenly monitor is stop working, monitor has solid green light, looks every thing ok, I am getting sound of shutdown and starting windows and I am getting perfectly...
It does the same when attched to another PC? Otherwise it may have bad caps prblem like the 17" version as shwon here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VE710B/
which is very common to LCD monitors that are more than 2 years old.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 03, 2011 | ViewSonic VG700b 17" LCD Monitor
VG2230WM (Black, Gray) LCD Monitor: Will not power up, no LED power light...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 18, 2010 | ViewSonic VG2230WM LCD Monitor
VE910b - Veiw Sonic monitor, when i turn the computer on the monitor will flash for anywhere from 30 seconds to 10 minutes before it stops flashing and i can use it. When flashing it will go from black to...
The backlight inverter is failing or the power supply feeding it is not good.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | ViewSonic 19 VE910B 1280X1024 TFT LCD...
I have a Viewsonic VG175 monitor. Out of the
The back light inverter may have gone out, You need to look for 12~18vdc feeding the board, there are also surface mouted fuse on the board,
Jan 03, 2010 | ViewSonic VG175 17.4 in. Flat Panel LCD...
I have a ViewSonic VE910b 19" That the display stays black
What your both experiencing is a slow degradation of the inside light bulbs. Just like what happens to regular fluorescent bulbs, they slowly flicker out.
Best to buy a new monitor.
Take apart your old one, you'll find burnt out bullbs on the upper and lower chassis deep inside.
Apr 22, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Power light flashes momentarily; monitor will not turn on
It seems that you've already checked this no, but double check that the power cable in the back of the monitor is securely plugged in. My suspicions would be that there's some kind of breakage in the power cable itself. I suggest you inspect every inch of it carefully.
Nov 21, 2017 | ViewSonic 19 VE910B 1280X1024 TFT LCD...
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
ViewSonic VA721 monitor
this is only an educated guess based on my years of computer and electrinics experiance. I believe the problem is the AC inverter that supplies current to the monitors back light,it powers up and fails. the monitor is working but without the back light you get a blank screen.The problem is fixable, but the delema is that for a technician to troubleshoot and repair the problem may cost as much as replacing the monitor since the prices have dropped so much in the last few years.
Dec 23, 2007 | ViewSonic VA721 17" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VA1912wb 19" LCD Monitor Logo
245 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
