Question about Lexmark X7170 All-In-One InkJet Printer
Trying to send a fax ... error 2200. - Lexmark X7170 All-In-One InkJet Printer
    Genius:
  • 1,087 Answers
The 2200 error indicates the scanner stall or jam. In your case, the printer is not able to scan the page for faxing because the mechanism stalled. Here's an article on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link: http://bit.ly/cjxdtv. The article will guide you on what to do. But if problem continues, don't hesitate to contact Lexmark technical support to further investigate the problem. Thanks.
Posted on Aug 25, 2010
5 Suggested Answers
SOURCE: Hi, Remote Fax Error being displayed
you talked about pressing options 15 times. where this key is located please?
Posted on Mar 13, 2008
Ajkill
  • 2035 Answers
Set the DRPD in the settings to 9600 and then try send a fax ...
Posted on Jan 29, 2009
laxmankumar
  • 191 Answers
SOURCE: Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I get the error 2200 message everytime I try to
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Posted on Nov 10, 2009
Halfway through sending a fax I got an 'error 2200 - conslut your user guide' nessage'. Is there a user guide online or can you help me?
The 2200 error message indicates that the scanner has stalled. Please refer to this article in the Lexmark website to determine and resolve the problem: 2200 Error on the Lexmark X7100 Series All-In-One.
May 03, 2011 | Lexmark X7170 All-In-One InkJet Printer
Error 2200 on 7170 lexmark
The error indicates that the scanner has stalled or jammed. Here's an article on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link: http://bit.ly/aBUoJK. Just follow the troubleshooting steps on the page. If all else fails, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 27, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a hp 2200 all-in-one printer. For some reason it will not receive faxes . I tried to send a fax from work to my home fax & I got a no answer error. I tried calling the number & all it does...
For that you have to enable auto answer in your printer.
For that go to printer menu settings there you find option for enable auto answer in fax settings.
then it automatic receive fax.
Let me know if you need more assistance.
Thanks.
Oct 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
What happens if you dial the remote fax number as a voice call on another phone? Does that number pick up? Does it give you the modem handshake noise? If not, the remote side has a problem.
Can you fax other numbers? What happens when you dial your own fax line from another phone? If your fax does not pick up and talk to you, your fax may have a problem.
Jul 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Paper jam, error message, fax send comes out not ledgable.
Code 43 is a line error according to Panasonic.
I had this issue trying to send to a client yet I could send faxes to other #'s. So in my case it was a dead fax on the other end of the line.
Jun 13, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Scanner problems
try to change cableof scanner to pc.
Apr 01, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
