Question about Vacuums
We have an Oasis 30501-L water cooler and it has been stored for some time. How does a person clean it out before using it?
Myy wertheim steam mop is over 2 years old. Wont steam, have followed manual instructions for maintenance etc and still wont steam. Is it time to replace it.
If you live in a hard water area and haven't been using distilled or deionised water, it could be a good time to replace it due to a probable internal build up of scale. If it hasn't already caused trouble it is almost inevitable soon.
If you have been using soft water and/or descaling regularly the steamer should still be relatively clean internally and it would be worth finding a competent person to check the circuit, cable, switch, but not at full retail prices or if it must be replaced it will be wasted money. Find a friend or neighbour who will do it for a beer...
Jun 01, 2017 | Vacuums
I stored my FH50220 in my storage unit over the winter and now it will not spray water
If your storage unit got below freezing it may have frozen and damaged something. It's hard to drain all of the water from pumps, tubes, valves, heaters etc. inside a carpet cleaning machine. If a machine must be stored where it may freeze one way to keep it from freezing up is to pour automobile windshield washing solution into the fresh water tank and run it through the machine until it comes out all of the Jets and cleaning attachments. Remove the fresh water tank and continue to run the solution through the machine to flush the windshield cleaner out of the machine. Be sure to use a cleaner with the proper anti-freeze rating and run fresh water through the machine before using it to clean carpets.
Apr 01, 2016 | Hoover FH50220 Vacuum
Steam wont come out although filled with water and heated as required
If you are using tap water the holes where the water comes out are plugged. You will have to take it apart to clean. After that you should use distilled water you can purchase at your local grocery store. That is what my wife uses after I insisted.
Dec 01, 2013 | Vacuums
Hi, I have a older model Sunbeam water cooler that hasn't been used for a while ..Need to know how to clean and sanitize it? got any ideas
Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Jun 07, 2011 | Vacuums
Prima water cooler just noticed that the cold water is not cold. Looked in back and copper coils all iced up.. turned off and put cut to collect water, what needs to be replaced> have another...
try to adjust to lessen the setting of thermostat maybe the setting is to full thats why the thermostat cannot cut off after the water chilled. then observe the unit.
Mar 02, 2011 | Vacuums
Hamilton beach water cooler has mildew taste
Hi, your post is showing a photo of a vacuume cleaner? Don't think so,lol. If you water cooler has a mildew taste in the air, you need to go to a hardware store, just about any, and buy a roll of evaporative water cooler tablets that you add to the water to prevent this from happening. They are the size of a quarter and come in a roll or other container depending on the amount you buy. They have different names, so just ask for the tablet additive for your water cooler and they will no what you need. I hope this has helped you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 23, 2010 | Vacuums
Bissell 9300 will not spray liquid
I've got the 9300. Same problem occured during warranty period. They replaced the pump and it has worked fine since. The service person said never to put hot water in the tank (whish is what I was doing). If you put hot water in the tank, with the heater on, the water gets boiling hot and then the plastic impeller on the pump expands and the pump shaft simply spins and does not turn the impeller. Don't know if it is true or not, but his explanation sounded reasonable. Since then, I have used only lukewarm water in the tank and it still squirts fine (about 2 years). I also shut the heater off and squirt some fresh water in order to keep the pump cooler if I need to pause the cleaning for more than a few minutes. I took it apart one time to see what is inside. The pump is not real easy to get to. Good luck.
Mar 28, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Abused by family member left water in basin. motor makes noise
Hi, If water was left in the tub when it was being used for wet pick-up, and wasn't emptied before using again for dry, you have sucked water up in and on motor windings. About the only thing you can do at this point, is to let the motor dry for a day or so and see if it continues. Check to see if something didn't get caught in the motor that may be making this noise. I hate to tell you but you may loose the motor. Time will tell. If you still have good suction, I would continue to use it until it dies on you. Check for any debri and dry it good. Keep me posted.
Best of luck to you,
Shastalaker7
Mar 01, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Soap solution valve on wand is not working.
No quick fix. Just make sure to run clean water through it before storing. Also, soak it in hot water, when it becomes plugged. I have dismantled my a few times, to clean it out, but have kept it clean to void future problems.
Nov 27, 2009 | Bissell 1425 Little Green ProHeat Handheld...
Bissell carpet cleaner
If water is spraying from the tool hose, then check the heater for a blockage. If the heater port is blocked, then the water can't flow back down to the spray nozzles, which could also be clogged. Most likely a clogged heater, it is in the handle.
May 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
83 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
