Question about Epson Stylus Photo R800 InkJet Printer
Printing problem my yellow, magenta and cyan seem to be mixing. I have used clean heads feature, but it hasn't done anything.
  • steve84062 May 28, 2008
    Thats was it
  • 426 Answers
Is it mixing because you are out of black ink and it is trying to compensate? that usally is why its happening, open your printer utility and change the setting . hope this helps
Posted on May 28, 2008
  • Lee N.
    Lee N. May 28, 2008
    let me know if i can help with anything else feel free to e-mail me at fixya@whypayforhelp.org
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
How do I correct error c4152?
Magenta Print head (print head has the LASER inside of it that writes the image on the drum) in this case it is the magenta LASER. Open and close the front door to reset. If it comes back replace the print head. Normal done as a set of all four. (Black, Magenta, Yellow, and Cyan). Worse case is the relay board is bad or the Image control Board$$$$$$$$$$$$$$$$.
Try this site as a start:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 04, 2015 | Konica Minolta Konica Bizhub C353 Drum...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Two problems: 1) I have had to replace the cyan, magenta, yellow, and black inks many different times and it seems like very often too, but I have NEVER had to replace the light cyan or light magenta...
If your documents look good when they are printed then the printer is working just fine and you dont have to be concerned about the ink use.
If the printer was not using the other cartridges correctly, then you would see areas that were missing color or were the wrong color when you tried to print. If the ink on a cartridge was not flowing freely the printer would stop printing and display error codes until the problem was corrected.
Being these things are not happening, I think it is safe to assume that it is working properly.
To correct the problem with the black line on the side, try cleaning your print heads and using the maintenance features on your printer. To access these features find the "menu" button on the printer and push it. Then scroll the features displayed by using the arrow keys on the printer until you see "maintenance". Then push the "ok" or "enter" button on the printer and continue using the arrow keys to find the cleaning options for print heads. Follow the instructions for cleaning the print heads and repeat the process a second time for good measures.
Regular maintenance of the printer should eliminate the black line problem and provide better printing results.
Oct 26, 2010 | HP Photosmart C7280 Laser Printer
MY Printer Brother : MF 235 C has problem with printing the Magenta and Yellow. bought 4 original catridges for Black , Cyan , Magenta and Yello. The Cyan and Black are printing with blurish and faded...
Try the instructional video below. ou can get a sringe from Pharmacy department of any store for free and tubing can be purchased in stores like walmart. It is a simpole fishtank airtube. I have a link below for walmart air tube. Aqua Cultures Standard Airline Tubing 8ft Walmart com
May 30, 2017 | Brother Office Equipment & Supplies
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
Faint repeating
I have problem with my Phaser 6130 Laser Printer, I changed toners (black, cyan, magenta yellow). My printer printing only cyan and magenta, colors black and red is very, very light. I cleaned my printer exactly. Everything is ok, but he does not has a black & magenta toners. What's happen? I don't know.
Donna
Jan 30, 2009 | Office Equipment & Supplies
Epson Stylus Photo R800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
