Question about Microwave Ovens
GE Profile Model # JVM2070SH001
Microwave shuts off a second or two after starting... It acts like it reset due to having to reset the clock everytime.. I pulled off the vent covers and both are clean. What else can I try
  • Microwave Ovens Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
Check out the following link. Most likely the magnetron is causing electrical interference with the control panel and the following link has a solution. It works, but the question is it safe? Here is the link:
http://www.fixya.com/support/t122426-microwave_shuts_off_after_few_seconds
Posted on Aug 09, 2010
Mine did this and sears came out and remvoed the grill assembly (the top strip that vents open when you turn it on. The assembly itself is made of cheap plastic and was broken from use (I assume) because it was not able to easily open, the oven woudl shut itself off. Without the assmbly, the mircowave works just fine. Im tryng to repair becuase replacing is expensive (around 120 online, and the ripoff artists at Sears wanted OVER 400 DOLLARS for the part (on top of the 129 they charged me to come out.) Try unscrewing the screws on the top of the oven and removing this grill assembly and see if your oven will work. Hope this helps.
Posted on Dec 27, 2009
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
The keypad of my Profile 2.0 over the counter microwave is frozen in the clock mode
Remove power for 15 minutes and see if the clock resets. However if there is no action on the control panel the fault can be either due to a faulty control pad, a faulty board.
Unless the unit is removed to check there is no other option.
Nov 06, 2011 | GE Profile Spacemaker Over-the-Range...
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE SPACEMAKER 2 JVM2070SH001 MANUAL HOW DO i REPLACE CHARCOAL FILTER?
That's covered in the owner's manual. If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts (including filters) here.
Jan 10, 2011 | GE Profile Spacemaker Over-the-Range...
Ge profile spacemaker 2.0 model#JVM2070SH001 - HOW TO REPLACE CHARCOAL FILTER.
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave stops running
Mostly with GE I find this to be bad connections at the fuse holder or a bad fuse due to a bad fuse holder. It will break connection and reset the unit when the connection gets hot and expands and then opens and stops power from getting to the unit.
Aug 14, 2017 | GE Microwave Ovens
Fuse in Microwave blew , now starts running when door is opened
You have one or more defective door switches, or the door switch mount is loose or damaged. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 23, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
1,292 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
