Question about IBM Computers & Internet
Booking up past the IBM logo I get a fan error
    Brigadier General:
  • 10,406 Answers
The cooling-fan inside your computer either has seized-up, and is not spinning at all, or it is spinning "too-slow", i.e., less than the minimum speed at which it should spin.
So, your computer will soon be overheating.
Take it to a qualified computer-technician, for trouble-shooting & repair.
Posted on Aug 25, 2010
My Lenovo Thinkpad T60 Won't load pass thinkpad Logo. I can't access Bios and ThinkVantage button is useless PLEASE HELP!
A burning smell is a good indication that some component burnt up. Could be a fan and that would cause it to shut down. If it's hung on the logo I would start by removing the memory, hard drive and optical drive and see if it boots past the logo. If it does then power down and add one item back in and test again until you find the bad part. Can you hear the fan spinning when you power it on?
Dec 02, 2012 | IBM Lenovo ThinkPad T60
IBM Thinkpad x41 tablet does not go past the ibm boot logo at startup. BIOS does not open or any of the other options at startup. What should i do ?
If you have the machine on a dock of any sort, remove it from the dock.
If that doesn't help, try taking out the hard drive. See:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-54584
for instructions.
If you get past that screen, put the hard drive back in. If you're stuck in the same place, you may have a bad drive. If it boots. . .great!
Feb 21, 2011 | IBM Lenovo ThinkPad X41 Motherboard...
I power the device on and get the 'IBM ThinkPad' logo screen. Nothing happens after that
Since you are getting the IBM Thinkpad Logo it is confirmed that you have no hardware error. All you need to do is restore the operating system. most of the IBM laptop has an inbuilt recovery option. just press the access IBM/ Thinkvantage (blue button) immediately after pressing the power button and follow the screen..
hope this helps.
Apr 06, 2010 | IBM ThinkPad A22p 2629 Notebook
Wounlt go past IBM logo and cant access F1 or F12
Did you check the fans to see if the unit is overheating?
Clean out all ducts and airways from the fans and try this again. Write back to me with your results.
Mar 15, 2010 | IBM ThinkCenter M50 (8189A1UJ) PC Desktop
Ibm thinkpad type: 2652-BVG Issue: Boots up past the thinkpad logo to the bios setup.Has fan error and 0187 warning.
one of the cooling fans is out or going first look in the fan outlet vent see if its pluged with dirt or animal hair or anything really if it is use a compressor and blow everything out (this should be done on all electronics at least every three months anyway) if clean then fan needs replaced
Dec 12, 2009 | Computers & Internet
Fan error on ibm thinkpad
take it to the technician remove the fan clean the dust then put it again if its not working then change the fan
Sep 04, 2009 | IBM ThinkPad G41 Notebook
What is error 00173, 00192, and 00163
Error 192 means a fan error, to test this measure the voltage of the backup battery. If the
voltage is not correct, replace the backup battery. Check the fan and the system board.
Error 163 means the time and date is not set, to set the time and date hit F1 when you see the IBM logo and set the time and date.
Error 173 means the configuration data is lost, to sort that select OK in the error screen and set the time and date.
In most case its the CMOS battery that's run low and need to be changed for a new one, so for the time being you will have to keep setting the time and date and it will boot to windows.
Good luck
Jun 15, 2009 | IBM Thinkpad 600 System Board Motherboard
Ibm t43, xp pro won't recognize my WD my book
please write down the error and contact me now
anaesarora online
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Error code 175
If you have access to the internet another way, search the error code by googling it, or going to the IBM website and searching it anf for solutions.
May 19, 2008 | IBM ThinkPad A21m 2628 Notebook
Key board stops responding when windows loads
your mouse freezes; you should only use system restore as a last resort
any virus/spyware you had in the past will come back
turn the computer off(you may have to shut power off pressing on power button)
when you see ibm logo, tap F8 key repeatedly until your hear beeps or a high pitched noise
use option safe mode; use 'most recent config where my settings worked' option in safe mode(use up and down arrow keys to highlght, then press enter)
If that does not work, try another(earlier) restore pt w system restore or install mouse drivers on a cd on another laptop, then
place in cd rom and try to install it on the problem laptop
if this is no good, you should really reinstall windows, back up impt docs, etc.(delete old partition)
that model has a built in restore function by pressing F11 on startup, it will restore your piece to factory condition(along w spyware that comes along w the builtin ibm utility)
I had the same exact laptop, the fan got noisy, so I replaced it w another that was from a good t30, guess what:
"fan error"
Ibm laptops are too problematic to work on
thats why I use dell
if you need more help, msg me or post on here
Feb 25, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
103 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
