Question about Gaggia Titanium Espresso Machine
The float in the water tank keeps sinking resulting in fill water tank even when full
  • mark39897 Aug 26, 2010
    how do I change the float ??
    President:
  • 1,618 Answers
Sounds like there is a hole in the float, either replace the float or the tank.
Posted on Aug 26, 2010
Testimonial: "thanks very much good advice"
  • Ernest R
    Ernest R Aug 27, 2010
    You can pick up anew float from your nearest gaggia dealer or from servicesunlimited.com, you just have to pop the lid holding the old one in place and drop in the new one and cover.
Display on Saeco Magic Comfort+ says "Fill Watertank" even when tank is full. Removing and resetting does not help.
Hi
This is usually a magnet in the water tank or sensor inside the machine. First do you have the grey magnet in the water tank? If no magnet in the tank, that is the problem. The magnet floats when the tank is full and sinks when its empty. It sends a flux signal to the sensor inside the machine. If the sensor is bad inside it doesn't pick up the flux field and you get the "water tank empty" display.
May 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
Tip
Krups espresso machine keep asking me fill up the water tank even it is already...
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons.
First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it cannot be fixed then you need a new float.
If you want to fix it temporary until you find a new float you can use a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
on Aug 16, 2010 | Coffee Makers & Espresso Machines
Keep asking me fill up the water tank even it is already full
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Apr 02, 2010 | Krups Small Appliances Espresso Machine
My washer keeps filling with water even after the cycle is going. I put it on small load, it fills to the right level for a small load, the cycle begins and soon the washer is overflowing. Even after final...
hi there......wow !! your using a lot of water...sounds like you have a failed inlet valve resulting in water flowing continually into the machine.....remedy relace the inlet water valve
regards Sir Galahad
Aug 12, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Fill water tank message appear even when tank is full
Check the float in the water tank,it can stick or leak water and sink to the bottom.
Jul 17, 2009 | Gaggia Titanium Espresso Machine
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Krups XP9000 won't recognise water tank is full
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Feb 04, 2009 | Krups Small Appliances Espresso Machine
I Have a Krups Espresseria automatic coffee machine & my problem is the water indicator in the water tank does not rise when the water tank is full so the machines keeps telling me to take the water...
Good luck
Nov 17, 2008 | Krups Small Appliances Espresso Machine
Water tank level indicator sinks to the bottom when water tank is full.
I think the float is up and down, try to take it out and turn it.
Look at the float in the other tank to see if it is same position, the rounded side should be down.
Let me know if you get it to work.
Best regards
/Mirran
Sep 04, 2008 | Saeco Royal Cappuccino Espresso Machine
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
143 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
