Question about Dryers
WHIIRLPOLL DRYER DOES NOT START , BELT NOT BROKE
  • 7 more comments
  • Anonymous May 16, 2008
    When I push the start button for the dryer, nothing happens. Once I turn the dial and set the amount of time, cycle, etc. and push the button, I can hear the "ticking sound" but I push the button and it won't come on. I unplugged the dryer and plugged it back in and it still does not work.
  • airricca May 19, 2008
    the dryer wont start but when the dial is on the timer you will hear a ticking sound but the dryer wont start. I have unplug it and it still wont start.
  • mylodylan Jun 16, 2008
    dryer has power. I reset the breaker and the light goes on inside the drum when you open the door. I checked the door switch and the start button and they both seem to be doing what they are supposed to be doing. At the first sign of a problem you had to press the start button a couple of times before the dryer stayed 'started'. After a while that no longer worked and now it just doesn' start.
  • Anonymous Oct 18, 2008
    dryer will not start
  • miraclebinhi Feb 01, 2009
    The lights work and I can hear the ticking when I start it, howver it does not start.
  • Csugarbrown Mar 01, 2009
    I have a Roper Dryer and I hear the ticking, but it will not start. What could be wrong with it?
  • Anonymous Mar 14, 2009
    The dryer won't start when I push the start button. But breaker is fine, the light is on inside, and the timer rotates and resets freely.
  • nuggin Apr 19, 2009
    whirlpool dryer has quit wirking. checked the circut breaker and it is fine. checked the lint hose and it is clear. Can hear ticking noise when it is set. but when the start button is tried NOTHING.The model number is LER 5636EQ3
  • Anonymous Apr 27, 2009
    whirlpool dryer won't start, timer is ticking
  • 4 Answers
Replace the control board 8546219. about 125 dollars
Posted on Dec 23, 2008
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
Dryer won't start no, noise, no ticking, pluged in
Posted on May 24, 2008
Dryer heats want start
your belt is most likely either off the tract or broken
Sep 08, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer not running after start turned
do you mean that if you hold in the start button it will run but when you let it go it stops,if so you have a bad belt pulley switch.it's a safety so if the belt breaks the dryer won't run,all it is is a cherry switch,a black switch with a white button sticking out of it,the belt pulley hits it and pushes the button in but the switch fails internally or the belt is broke,if the belt isn't broke replace the belt pulley switch.
Oct 20, 2013 | GE Dryers
Won't start
2 reasons a dryer won't start, either the door is not closed (or the door switch is bad), or the belt that turns the drum broke. The dryer has a switch on it that will shut off the dryer and keep it from starting if the belt is broken.
Aug 02, 2013 | Frigidaire Dryers
Press the start button on my dryer and it will not start. There is power and the belt is not broke help me
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 15, 2011 | Whirlpool LGB6300 Gas Dryer
I have an Estate electric dryer. there is power to the unit but it will not turn on.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 30, 2010 | Dryers
Dryer not starting
check drum belt it has a switch that will not let dryer start if belt has broke or came off, if belt is ok check thermal fuse
Sep 28, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't go just beeps when start button
the belt may have broke and tripped off the safety switch. lay machine on its side and check the belt
Jul 10, 2009 | Dryers
Dryer only ''humms'' when you press start
It sounds like you have a broken belt.
Does the dryer blow are from the exaust if it does then your belt probly broke.
Dec 08, 2008 | Dryers
Dryer will not start
could be the start switch might be gone,there is a clip the hang down when u open the dryer door,it might be broke or the belt might be broke.
Mar 22, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
698 people viewed this question
Top Dryers Experts
