Question about Getac V100 Tablet PC
My Getac v100 has a backlight issue. An external monitor works fine but there is no visible display on the LCD. Where can I get the parts to fix this issue? Thank you!
    Brigadier General:
  • 10,406 Answers
Sounds like a bad "inverter".
Try any local video/TV repair store. Try eBay.
I presume that you have the expertise to disassemble the LCD, replace the "inverter", and reassemble.
Posted on Aug 25, 2010
Touch screen
I do not beleive it can be dont but be weary i have no linux distro to test this on
http://tldp.org/HOWTO/html_single/XFree86-Touch-Screen-HOWTO/
Mar 03, 2012 | Getac V100 Tablet PC
Gateway M275 display scambles
I suspect it may be a problem with the video cable coming from the convertible tablet, up through the hinged support for the LCD screen, AND/OR the screen Inverter.
I would like you to connect a VGA monitor, to the VGA port on the back of the convertible tablet. The VGA monitor will now be an External Monitor.
[ Looking at the rear of the convertible tablet, start at the Left side.
Vent, USB port, Monitor port. The Monitor port is the VGA port ]
The VGA monitor can be a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
Notebook OFF, monitor OFF, connect the VGA monitor to the M275's VGA connector. (Port)
Turn the monitor on. If a CRT type, allow it to warm up.
Turn the notebook on.
By the factory default settings, whatever is shown on the convertible tablet's internal monitor, should now be shown on the external monitor.
(VGA monitor)
If not, press, and hold down on the Fn key (On the bottom row of the Keyboard, all the way to the Left), and tap once on the F3 key.
(Top row of Function keys. The F3 key is the Display Toggle-Over Key )
No graphics shown on the external monitor? Hold down on the Fn key again, and tap the F3 key again.
There are at least three options available;
1) Convertible tablet's internal monitor - ONLY
2) Convertible tablet, AND external monitor
3) External monitor - ONLY
If graphics are fine on the external monitor, you have a problem with the video cable, and/or the screen Inverter. At this time we will bypass the LCD screen, and come back to it.
At the bottom/middle of the tablet's LCD screen, is the Hinge. The Hinge Cover is 'T shaped', and has one single Philips screw holding it on.
If you remove the screw, and the Hinge Cover, you will see two wire harnesses.
One Black, the other White.
See that these two cables are plugged in tightly to the connector.
After checking this step come back in a Comment, and state your findings.
Regards,
joecoolvette
[ Additionally;
Here is the Service Manual (Free) for the Gateway M275 Convertible Tablet,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Where it states - Gateway 400, go down to the second line, and across to M275. Left-click on M275.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Dec 11, 2011 | Gateway M275 Tablet PC
My system is not display bright screen
This sounds like your backlight on the LCD screen has blown and may need replacing. Hope this helps.
Just make sure the brightness has not been turned down and you can check by connecting it to an external monitor to see if it works. If it does, then that will be your problem.
Hope this helps
Jul 29, 2011 | Fujitsu Tablets & eReaders
Tc1100 Blank Screen
You have identified your problem/fault by plugging in an external monitor and the image is OK. This proves the video card is OK and the fault could be the inverter or most likely the CCFL lamp.
The flickering screen indicated the CCFL lamp is faulty, it is a mini fluro tube which provides the back-light to the LCD. The inverter supplies high voltage to the CCFL lamp. It could be faulty and it is easier to replace.
For service, parts and DIY info check out LCD Parts - use this link to their WEB site : -
www.lcdparts.net
Oct 10, 2009 | Compaq tc1100 Tablet PC
My Epson EMP-S4 LCD projector does not display images from my Averatec C3500 laptop. It displays "No signal".. Do i have to press any keys before it would display? I suppose it would automatically project...
When you connect a data projector or external monitor to the external video port on the laptop, power up the data projector or external monitor first then the laptop. The video info will automatically divert to the data projector/external monitor automatically.
If you have already had powered up the laptop first, most laptops will allow you to toggle between the LCD screen and the external video port by pressing the Fn key plus one of the Function keys, this key will have a screen/laptop symbol.
Sep 08, 2009 | Averatec C3500 Tablet PC
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
HP Compaq 2710p: External monitor does not display anything
The display properties indicate the hardware is working, so it's likely just a setting.
On HP/Compaq models you will see a picture, usually on the F4 key that looks like a screen with two lines beside it.
You need to hold down the Fn key(bottom left) and then push the F4 key at the same time to cycle between LCD, external or both.
If it is a newer model, a menu will pop up when you do this asking if you want to duplicate the LCD on the external, switch to the external or extend the desktop onto the external. Select the appropriate setting or continue holding down Fn while pressing F4 to cycle between the settings to the one you want.
If you have re-installed the computer at some point with anything other than the factory recovery set this may not work and I will have to give you a longer set of instructions.
If this works please rate this as fixed, if not reply back and indicate what version of windows you're using and I will post the instructions for the "long" way.
Chris
May 26, 2009 | Compaq 2710p Tablet PC
Lenovo X60 laptop display has stopped working
The backlight is broken. These are small flourescent tube lights about the width of a pencil lead. You dropped the laptop and the bulb broke. It will have to be replaced. The driver has nothing to do with your problem, reinstalling it will not get your picture back.
Dec 13, 2008 | Lenovo ThinkPad X60 Tablet PC
Laptop Screen Dull
Look a the screen real close, if you see a faint dark version of the image, this could be a backlight issue, otherwise a screen cable or a logic board issue. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, it's a pretty arduous repair that requires 1-2 hours for a trained person. It's feasible to do it yourself if you're tech savy, but you'll most likely have to google for guides that show you exactly how to replace the backlight step by step. Check on how to take the screen apart and make sure inverter is still connected properly. If so, you have a backlight issue. I work for Computer Repair NYC and i have to fix this problem a lot, it's so easy to break the lightbulb in the process.
Nov 18, 2008 | IBM ThinkPad X41 Tablet PC
My screen is showning flickering white lights
Hi, To confirm that indeed you laptop CPU is working normally, you can try plugging an external monitor. This will also verify that your onboard video or memory is not the issue. Assuming you have tried the above, as to the screen flashing, it can probably be the LCD panel display. It can either be the video converter or your backlight inverter (or CCF fluorescent tube). Any of the two would require opening the display panel and component level repair. Should you not be comfortable cracking the display open and circuit analysis/diagnosis, you may need the services of a qualified professional. Hope this give you an idea and work out for you. Good luck and post again how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | Acer TravelMate C312XCi Tablet PC
Getac V100  Tablet PC Logo
184 people viewed this question
Top Getac Tablets & eReaders Experts
Are you a Getac Tablet and eReader Expert? Answer questions, earn points and help others
