Question about Ovens
I HAVE A WHITE WESTONHOUSE DOUBLE OVEN, THE GLASS IN THE DOOR IN THE LOWER OVEN HAS BROKEN I NEED TO REPLACE: SERIAL NO 34030074 FDAAE0050001724 INOX 3.85KW VIDEOD7SY551E E72A/VD5501TE 05-205404 230/240V 50HZ CAN YOU HELP
  • justeddiemc Aug 29, 2010
    You have not read my ? the door glass is broke & i need to replace it
    I KNOW HOW TO TAKE THE DOOR OFF, WHERE CAN I BUY THE REPALCEMENT DOOR FROM?????????
    Genius:
  • 1,417 Answers
the bet pleace to get the part you need to replace your broken glass on your oven is to order for it on line at the below address
products.noelleeming.co.nz sella.co.nz gandhiappliances.com comparison.com.au
all the above store offer a competitive price and good service in conjunction with westonhouse double oven.
hope this help ?
thank you and thanks for using fixya.
Posted on Aug 29, 2010
  • 857 Answers
Follow these steps to replace your oven door glass:
•1
Disconnect the oven's power cord from the electrical wall outlet. Although you will not be working directly on electrical components, it is good safe practice to disconnect the power source from appliances before making any repairs.
•2
Open the oven door halfway. Place a large nail or screw into the empty hole on the side hinge along the side of the door. A hinge is on each side of the door. The nail will keep the hinge from closing into the oven after you remove the door. Close the door as far as the nails will allow.
•3
Grab the sides of the oven door with your hands and pull the door straight up until the door stops. Push the top of the door toward the floor and pull the door toward you to release the door from the hinges. Lay a sheet on the floor and place the door on the sheet with the handle side facing the floor.
•4
Remove the screws that secure the inner liner to the outer door with a Phillips-head screwdriver. Some models only have two screws at the top edge of the liner. Other models will have up to six screws on the panel and two on each side of the door. Lift the inner panel up and slide the inner panel away from the outer panel.
•5
Use the Phillips-head screwdriver to remove the two inner screws that secure the door handle to the oven door. Lift up the oven door and pull the handle and the top trim behind the handle away from the door.
•6
Remove the three screws on the bottom edge of the door that secure the bottom trim to the oven door with the Phillips-head screwdriver. Pull the bottom trim off of the door. Locate the two screws that secure the right side hinge assembly. The hinge assembly is the part on the inside of the oven door that the hinge slides into. The screws are on the bottom edge of the door directly under the hinge assembly. Remove the screws with a Phillips-head screwdriver and pull the hinge assembly out of the door.
•7
Fold the door insulation back and pull the broken oven door glass and frame out of the door. Put leather gloves on your hands and pull the broken glass out of the metal frame. Place the replacement glass into the frame and set the glass and frame back into the oven door. Position the door insulation back over the edges of the metal frame.
•8
Slide the hinge assembly back into position and secure the hinge assembly to the oven door using the two retaining screws. Reattach the bottom trim and secure the trim to the oven door with the retaining screws.
•9
Lift the top of the oven door up slightly and line the upper trim and door handle into position. Secure the upper trim and door handle by attaching the retaining screws from the inside of the door. Tighten the screws with a Phillips-head screwdriver but do not over-tighten.
•10
Slide the inner panel back over the oven door and secure the inner panel to the door with the retaining screws. Pick the oven door up by grabbing the door at the sides with both hands.
•11
Place the bottom edge of the oven door over the two side hinges on the oven. Line the oven door slots over the hinge pins and push the door down until the hinge pins lock into the oven door. Open the door slightly and pull the nails out of the hinges.
•12
Close the oven door and plug the power cord to the oven back into the electrical wall outlet.
  • 4,323 Answers
Hi
Remove the outer glass, bottom trim and heat shield. Now, remove the six screws holding the frame to the inner liner and lift the frame.
The oven door seal is held to the inner door liner by spring clips. To remove the seal place a flat blade screw driver between the seal and liner beside the clip and lift the screw driver.
To open the oven door and outer door glass open the door completely, and lock the hinges with hinge lock. Raise the top of the door and at the same time roll the bottom of the door and hinges out of the front frame. Remove the door now and place it on something that will not scratch the liner. Now, remove the five screws holding the bottom glass trim to the inner door liner and slide the glass and trim down and off. Now remove the heat shield by removing the six screws holding the shield to the inner glass and lift the shield off.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 25, 2010
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
I need to replace the glass door front on my GE Profile 27" double wall oven JK955. Other than the outside glass being broken the rest of the door is fine. Can I purchase replacement glass?
Yes, but i believe it comes with the door handle already attached. Full model number, upper or lower and color is needed for looking up the part number. Expect to pay $210-280
Mar 03, 2010 | Ovens
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Door Glass
The only solution seems to be ordering a custom glass piece matching the dimension of the glass on the oven door. However, since my oven is white I would like the door to be white too. Although I have found glass guys who can tint the glass door dark, I have not found anyone who can color it white. Let me know if anyone knows such a glass vendor.
Mar 14, 2008 | Amana AOGD2750 Gas Double Oven
Replacement glass door
all my online part lookups also claim NLA. keep looking though cant imagine they're all gone everywhere
Mar 06, 2008 | Amana AOGD2750 Gas Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Dec 10, 2007 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
104 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
