Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
What is the temp. supposed to be for a treezer c and f
    Sergeant:
  • 224 Answers
Should be set at 0°F (-17°C) or lower, but definitely not above 5°F (-15°C).
Posted on Aug 25, 2010
Hi.. I have a defy upright freezer.. it is currently displaying an error "c2 !". Defy say this is because of the change in outside temp. Is this true, how long is it supposed to last? Many thanks.
If unit is not in a controlled environment yes temp will be confused and will take 24 hour to correct but if outside temp is changed it will do again and again all units designed for controlled temp room not outside in garage or out buildings with no heat or cooling controled room
Feb 28, 2017 | Freezers
The freezer freezes two hard , there are 2 switches on it are they both suppose to be on?? one is orange and one is white.
Well hello...on your freezer...the orange switch is for "fast freeze" and should not be on constantly...only when you want to freeze items really fast.If you have it on...turn it off.Also do you have the temp control set at maximum...If so...try to reduce the seting by one number.If not...leave it as is.Give the freezer about 24 hours to re stablize.That should do it...also...you will notice a reduction in your electric bill as the fast freeze switch causes the unit to draw a greater amount of electricity..MAKE SURE the orange switch is off...I hope this was helpful....PEACE...
Jan 05, 2012 | Haier 7.3 cu. ft. / 207 liter Chest...
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer Not Fan not running!
Most all commercial freezers have some sort of fan delay/ defrost termination device. Commonly called a "Klixon" (pronounced clicks-on). It is a device that is attached to the evap. It's function is to terminate the defrost cycle when the evap reaches a certain temp, say about 50 degrees or so, to ensure there is no build up of frost/ ice on the evap. It then allows the compressor to run, and cool the evap down to a reasonable temp., say about 20 degrees, and then let the evap fan come on. It prevents overloading the compressor during a high temp condition, and it also prevents circulating warm air left from the defrost cycle. I believe this device is most likely your problem. With no air circulating, the box will no cool down.. I have seen them burn and/or slhort internally. They can come apart. too. I would look here for that problem. the True manufacturing website does not give alot of info on this piece of equipment, such as a wiring diagram but manuals are available.
Check this out and let me know how it comes out.
May 17, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Freezer frosting up
I need more information. If this is a frost free freezer with an internal fan I need to know what the freezer temp is. If a manuel defrost it is supposed to frost up. You defrost it 2 - 3 times a year when the frost builds up over 3/4 inch. If it frosts up faster than this check to see if the door is sealing all the way around. There should be no gaps or cracks in the gasket.
Jul 10, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Not all the shelves are getting cold
All the shelfs should be getting cold starting at the top and working down. It may have a leak in the system or a restiction not letting the freon flow. It could of had the problem before the defrost. Small enough problem to stay frozen but won't bring back down to temp. Check to see if it's still in a sealed system warranty if so call for service.
Apr 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
