Question about Kenmore HE2 Plus Front Load Washer
Fault codes meanings for kenmore front load washer model 110.47512600
Http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208540259.pdf
Posted on Aug 25, 2010
the dr
  • 447 Answers
SOURCE: Kenmore Elite He5t Washer Error F24
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
SOURCE: Fault code F20 on kenmore he2t clothes washer
I had the F-28 code error on my 1-1/2 year old Kenmore HE2t. The door wouldn't unlock and I couldn't get the clothes out of it.
The repair tech, after calling other repair techs, decided it was the central electrical unit, page #8540540 (Whirlpool) -- now Part No. W10163007. I ordered it online for about $250 cheaper than the tech was going to charge (not including the additional labor charges).
Posted on Jun 23, 2008
duby1990
  • 370 Answers
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
SOURCE: Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Posted on Apr 03, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Kenmore HE2 Plus fronload washer is showing F- as an error code. there are no numbers in the error code. just "F-" i cannot figure out what that means
press and hold the power button until the machine resets,then if machine resets, ok. but if machine shows a fault it should give a full fault code.adrian,,,,,,,
Jan 24, 2015 | Kenmore HE2 Plus Front Load Washer
Error code f 02
I think it's a slow drain fault. But would need full model number to say for sure. Still it wouldn't hurt to check the drain pump for crud. Here are some vids that might help. Don't worry too much about brand specifics. Many brands share identical and similar parts.
http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
I am getting an F30 flashing on my washer. Why
Please check the full model number of the washer. Kenmore appliances are built by other manufacturers and the fault code will depend on that manufacturer.
However, the F30 code is most likely for a Kenmore washer built by Whirlpool. If this is the case, the code means a problem with the detergent dispenser. The dispenser is controlled by lever that needs to move between two points as the gears go through the cycle. Sometimes the lever gets bent out of position or the control wires (or other items) get into the gears and blocks the motion. Sometimes, you can hear a clicking sound as the dispenser tries to engage. If you take off the top of the washer and then run a wash cycle, you can observe this action. Check what may be blocking the dispenser and adjust things so that everything moves freely. If that fails to solve the problem, replace the dispenser.
If the washer is under warranty, contact Kenmore. Most Kenmore appliance parts are available from Sears Parts Direct . However, you will need the full model number. (The model number has a 3 digit prefix that indicates the manufacturer. The last 8 digits are the product model. There will be a period after the first three digits. Most front load washers will have the model number inside the door on the frame.)
If you post a comment with the complete model number, I'll be glad to offer additional help and the exact parts diagram for your washer.
Aug 24, 2012 | Kenmore Elite 45986 Front Load Washer
What does F06 mean?
F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
A failed drive motor.
A defective motor control board.
A failed main machine control board.
Hope thie helps (remember to rate and comment this answer)
Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
What does F 35 mean
You could find out by removing the bottom panel on your washer and fishing out the "tech sheet". That will give you the fault codes.
Plan "B" you could retrieve the model number and check HERE to download the tech sheet that would give that Fault code. Now let me see if i can guess:d31fdad.jpegNope ain't got a clue.
Sep 22, 2010 | Kenmore HE2 Plus Front Load Washer
Fault code '' F08'' what does this mean
The fault code F08 means that the heater relay cannot be activated. I would you check heater, and the thermostat for a fault. Replace them if required.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error code f17
Sears are a department store not a manufacturer, they contract other manufacturers to build the appliances for them and these are then sold under the Sears/ Kenmore brand.
To find who made your appliance, check the first three digits of your model number against the list below and this will give you the manufacturer of your appliance.
There is a site to help identify you washers "real" maker
The Link is here to cross reference it.then look up f17 and f25 on that make and model for better results
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
the Sears/Kenmore part is almost in the middle of the page. Then keep me posted by adding comments if you have any other questions
I hope this helps you out
8-)
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
111 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
