Question about LG LW5200ER Air Conditioner
LG 110 windo unit
My LG 110 window unit froze over repeatedly and now the fan runs but the compressor doen't engage.
I think that your gas has leaked.
Posted on Aug 07, 2008
LG window air unit. Been having trouble with control panel for months, but unit cooled. Now it will light up and fan will blow, but compressor does not kick in. Unit about 4 years old.
Possibly a faulty run capacitor in the control box. This is fairly common to LG. the fan motor and compressor use them to start and run more efficiently and when they fail the fan or compressor either don't start at all or run poorly. You can usually tell if you can hear the compressor 'hum' briefly then stop every 10 - 30 secs. this is the compressor trying to start but unable due to the faulty part. LG often have a dual capacitor (two capacitors in one case) so the fan may stop working also or at least run slower. They are common parts available at most electrical wholesalers although the genuine LG parts are normally dirt cheap. Need a model to check the circuit diagram to be more certain.
Aug 24, 2017 | LG Heating & Cooling
LG Air Conditioner LST182V-4
It may cause it to shut down if it's a safety thing, but it sounds like the compressor's faulty to me.
May 16, 2012 | LG Heating & Cooling
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 03, 2011 | Goldstar DH504EL Dehumidifier
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
Air conditioner runs for several minutes then
Take it back to the dealer and have them fix it, could be a compressor froze up or a fan froze up. If you disconnect the compressor and turn it on and it trips the breaker the fan is probably
bad. If you disconnect the Fan and turn it on and it trips the breaker
it is you compressor.
Jul 16, 2010 | Dometic Rooftop RV Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
Compressor runs for a sec and cuts off for about couple of minites and runs again
no changing or turning the plug, wont make no difference to the compressor, it sounds to me like your compressor is overheating. have you clean the condenser?? they get durty.
Apr 03, 2008 | Carrier XHC101D Air Conditioner
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
LG LW5200ER Air Conditioner Logo
99 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
