Question about Tricity Bendix WDR1040W Front Load Washer / Dryer
My tricity bendix WDR 1040 (about 6 years old now) has been great up until recently. there is now a very loud clunking sound when drum is spinning around - sounds like something large and it makes a heck of a noise..... any ideas what it might be, and if so is it easily fixed or should I start looking at prices for new ones! thanks
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
  • 135 Answers
SOURCE: manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
Posted on Feb 24, 2009
SOURCE: Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Posted on May 03, 2010
Drum won't spin on Tricity Bendix AW 1260W washing machine. What do I replace? Is it worth it? Machine is 7 years old.
Hi just food for thought,I normaly fix my things that are brocken,but I was told by a washing machine teck that the life span is usuely 5years,some times you get lucky and other times it gose wrong and you keep throughing money down the drain,I wish you the best and hope it works out for you if you deside to try and fix it.
Nov 21, 2016 | Tricity Bendix Washing Machines
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Loose Inner Drum on Tricity Bendix AW850W
Has the belt come off the pulley or the motor pulley? If not and it is in good condition has the belt stretched and not connecting properly or the motor slipped making the belt loose? Has the main pulley bolt come loose?
Dec 28, 2012 | Tricity Bendix AW850W Front Load Washer
I have lost my manual need a replacement
Hi.
Please click on the link below to open the manual in PDF format.
WDR 1040 W WDR 1240 W
Regards.
Ginko
Aug 31, 2011 | Tricity Bendix WDR1240W Front Load Washer...
Have a trcity bendix washing machine and during a wash it was making a loud baning noise from the drum when spinning . i went to look and there was smoke coming from the back of it and out of drawer . it...
It sounds as if the bearings have gone or something as serious that needs inspecting.This machine would have the normal 5 year major parts warranty and they would offer a repair but you would pay the call out and labour.Hope this helps.
Mar 25, 2010 | Tricity Bendix WDR1240W Front Load Washer...
Washing machine trips my electricity as its about to spin,
There is almost certain to be a small leak which could be from a variety of things. The water sounds like it has found its way onto your motor windings. Once it starts burning,carbon is left behind on motor.The decision to replace motor and possibly hole in drum is the question.Need to weigh up if a new purchase is possibly the right way to go. Remove covers to see if the source of the leak is visible.
Oct 02, 2009 | Tricity Bendix AW1000W Front Load Washer
Drum is really loose and when hits spin cycle makes loud noise
Most front loaders are pretty much the same and it sounds like your tub bearings are going bad. There is also a problem in some front loaders where the drum arms corrode and break. You won't know until you pull it apart. If you are doing the work yourself it depends on the parts you need. You can knock out old bearings and match some up.
If you are paying someone, it may be cheaper to buy a new washer..
Jan 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix WDR1040W Front Load Washer / Dryer Logo
175 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
