Question about Kitchen Ranges
I cannot find a place to put the Sim card - Kitchen Ranges
  • 835 Answers
What is your device your wanting to know where the sim card goes. Its currently showing me you want to know about a kitchen range. if its a stove. their isn't one.
Posted on Aug 25, 2010
Where to put sd and sim cards
It depends on your phone
You can open the back of your phone and place your SIM cards in the SIM slot and also our SD card.
You can also put your SIM and SD Card on the slot on the side of your phone.
Hope this helps.
Oct 27, 2015 | Cell Phones
Insert sim card
I'm not sure what the question is you are asking concerning a "sim card" but if it's How to put a SIM card in your cell phone you need a pin to put in the hole and it will pop open, However if your question is that your phone keeps telling you to insert a SIM card then you need to turn off your phone first and then go into the place where it's at and remove the SIM card and then put it back in and then turn your phone back on.
Aug 03, 2013 | Samsung E1107 Cell Phone
Sim card in a panasonic cf-h2
To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
Mar 22, 2013 | Panasonic Toughbook CF-H2ASFAZ1M 10.1" LED...
Where do I put the sim card in a motorola L7 please let me know. rattler7010@yahoo.com
In the above image i will clearly explain how to place the SIM card.
First please remove the back cover by pressing in outside(side ways)
and remove the battery and place the SIM card in the Gold plating.You have to slide the metal projector and place the Sim card.The RED marking is the place where you place the SIM card.The blue marking is the metal which you have to slide to place the SIM card.It is like a holder to hold the Sim Card
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
I have a sciphone i9 got it today it comes up t mobile when I put my sim in but I can't make or recieve calls or texts - can anyone help???
When you place your T-Mobile SIM card in the phone, what does it shown in the main desktop? It should say T-Mobile, if it doesn't, then you are either placing the SIM card in the wrong way, you are not in the best place to get a good signal, or the SIM card slots in the phone is in Flight mode. To check, go to the SIM card profile and make sure that it says Dual SIM Open.
Nov 03, 2009 | Dual Electronics CECT P168 Cellular Phone
I dont know the puk code
  • Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  • Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  • Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  • See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  • Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
WARNING
  • SIM cards come in different carrying capacities that may not work with all phones. Be sure to check with your provider to find out what size card your phone uses if you plan to purchase a SIM card from a source other than your cellular carrier.
  • Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself
Sep 25, 2009 | LG Vu CU920 Cellular Phone
Have Motorola F3 850 i put sim card in it it says no sim card
it could be that the sim card has damage to the underside connectors. try wiping these down very gently and place the sim as carefully as you can then try again.
May 03, 2009 | Motorola Mobility MOTOFONE F3 + 10 Virgin...
Nokia n73
Look, your phone don't recognize the card try to put another card, if it won't help clean the place of the sim card with a tooth brush its probably dirt.
Jun 29, 2008 | Nokia N73 Cellular Phone
Sim card]transfer card to new phone
Yes I believe so. Most phones these days store all the numbers in the phone and you must manually transfer them to the sim card. Then by putting the sim card in your new phone you will have your numbers. You can generally then transfer the numbers to your new phone, as it is handy to have them in more places than less. This way you have the freedom to change sim cards but always have access to those numbers for example.
Jun 13, 2008 | AT&T Blackberry Curve 8300 Smartphone
Sim card
THIS PHONE DOESN'T USE A SIM CARD.....DUHHHHHHHHHHHHH!!
Mar 22, 2008 | Samsung SCH-a650
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
