Question about Kenmore 92822 / 92824 / 92826 Gas Dryer
After i put the clothes in the dryer and close the door, the dryer will not start when i press start. It makes a short "click" sound and then doesnt start. The timer seems to be fine and the light inside the dryer is fine but the dryer wont start.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Start button will click but won't start
Hello. Your model dryer has a service flash on the lower door strike/catch concerning not staying closed or not closing properly. If the door is allowed to open too much, the door switch will not be closed and the dryer won't run. The part number for the new kit is 279570 and it includes 2 door strikes and several catches. You choose the ones you need. However, if the door *is* closing properly, you can put the unit in diagnostic mode(door closed, all indicators off) by pressing/holding any button *except* stop for 2 seconds, then releasing, press/hold 2 sec, release, press/hold 2 seconds, release-- all the indicator lights will light for 5 seconds, and an 8 88 will be shown in the display. If there are *no* active fault codes, the indicators will momentarily turn off and then stay on with the 8 88 displayed. If there is an active fault code, it will be flashing in the display. (ex. would be an "F" and "xx" where "xx" would be a number.) If you press the same button you originally pressed once, then again, then again, the most recent code will be displayed, then the next, and so on up to 4 stored codes. To turn off diagnostic mode, just press stop. I hope this helps you!
F01 PRIMARY CONTROL FAILURE
F02 KEYPAD
F22 OUTLET THERMISTOR OPEN
F23 OUTLET THERMISTOR SHORTED
F24 INLET THERMISTOR OPEN
F25 INLET THERMISTOR SHORTED
F26 MOTOR DRIVE SYSTEM FAILURE
F28 MOISTURE SENSOR OPEN
F29 MOISTURE SENSOR SHORTED
F30 RESTRICTED AIRFLOW
F70 NO COMMUNICATIONS BETW ELECTRONIC ASSEM
F71 " " " " "
F72 THRU F78 CONSOLE ELECTRONICS FAILURE
Aug 23, 2015 | Kenmore Dryers
I opened the dryer door to put in a load of clothes and the light inside flashed and went off. power comes on, i can set to the drying time, but when i press start i get 3 short quick beeps...no error
It sounds like maybe the switch that recognizes your door is closed my be bad or out of adjustment. Look for a 3/8" to 1/2" opening on the face of the surface that the dryer door meets. There may be a small plate that acts as the actuator. It may also be a small rod sticking out that gets pushed in by the door. Either way, try to actuate it with your hand or screwdriver with the door open and press the start button and see if that works. If not you'll possibly have to take the dryer apart to get at the switch. If you're comfortable with using basic tools this can be done and you just need to be patient while doing it. Test the switch if you have an ohmeter to see if it works. An ohm reading is fairly simple to do and meters cost less than $30 at a Home Depot. Don't get intimidated by their dials and number readouts. (O.L. = Open, 0 ohms = closed) If the switch doesnt change states it's bad and you'll need to search the p/n on the switch in Google. Someone on Ebay or other sites will likely sell these switches for $5 or less. Hope this helps.
Dec 02, 2014 | Dryers
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
Maytag Bravo 400 series won't start. I click the start button and it beeps but nothing happens.
Well first of all you can check door switch - If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. The door switch is a simple on / off switch to indicate whether the dryer's door is open or closed. The dryer will not operate when the door is open. If your dryer runs with the door open, the switch may shorted closed or there may be a dangerous electrical short in your dryer. If your dryer will not start when you press the start button and you hear no sounds, the door switch may be the problem.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Maytag Dryers
My dryer was working. I stopped it to take my clothes. When I went to put in the wet clothes my dryer would not start.
Try pressing on the door to close it and
see if it starts. It sounds like the door switch has failed or the actuating arm is bent. You should hear a click as the door just barely opens or is nearly closed. No click = no start. I.e. Door switch problem.
Jan 22, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer stopped working. Dryed a load of clothes
Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 17, 2009 | Whirlpool Dryers
Dryer won't start. Pressing "Start" button just emits 4 beeps.
does the drum turn? if it doesnt you can assist it and see it that is problem, have to remove top and push it. that would be capacitor on motor or jumper the door closed switch and try to spin.
Apr 21, 2009 | Dryers
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Kenmore 92822 / 92824 / 92826 Gas Dryer Logo
275 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
