Question about Combi Centre DX - Mango
Baxi Combi 80e
Hi the bolier does not fire up when i turn on the water or the heating, the pump seems ok, the switch on the fan clicks but the fan doesn' t go. Any ideas guys
  • Anonymous Nov 29, 2008
    baxi 80e will not fire up when calling for hot water but it will for heating
Boiler keeps saying fault on pump/low pressure
Posted on Mar 10, 2009
    Problem Solver:
  • 7 Answers
I need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
Posted on Sep 18, 2008
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Woke up the other morning with no heating or hot water from my 5 or 6 year old baxi 105e combi.i have,within the last 2 months, replaced the central heating temp sensor,and currently have the usual(and...
Per the User's Operating Instructions you want to check the condensate drain. Make sure it is free and clear. Also check the ingnitor, ensure there is no debris or buildup that could prevent it from firing properly.
Also, here are the Installation and Service Instructions that might be of help to you.
Without being onsite with toolbox in hand, I hope this information is very helpful to you. :-)
Mar 31, 2010 | Heating & Cooling
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Water gets hot then turns cold and runs cold then hot again
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Feb 04, 2009 | Combi Centre DX - Mango
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Combi bolier problem
either the h/w flow switch or diaphram reqs replacement or the secondary heat ex or (calorifier) is blocked and prevents the heat from leaving the biler to hget to he taps- the heat starts ok but backs up to the boiler very quickly causing it to shut down
Feb 20, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
1,756 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
