Question about Lexmark Wheelwriter 6 Series II Typewriter
Typewriter runs fine but won't imprint on paper - looks like the strike isn't taking place
  • jonistusek Aug 25, 2010
    I don't think it is the wheel - the part that raises up to strike the wheel to allow for the imprint on the paper is not moving. Do you have any other suggestions?
    The electrical components are working fine, but the part that should raise up to strike the wheel to imprint the letter onto the paper is not moving. The last expert felt it was the wheel itself, but the wheel seems ok (moving, etc.) but the part that should strike the wheel will not move. Could it be a faulty electrical part or connection?
  • Lexmark Master
  • 11,800 Answers
The strike is generated by an electromagnet so it's clearly its fault. Either the electromagnet is faulty (a short in the coil) or it's not commanded because either there's a bad connection or the mainboard has failed.
The only way to know which is to dismantle the machine and testing :start by checking the continuity of the coil, then if power is reaching the coil when you press a key , and finally that the command is leaving ther board. If it doesn't you must find why by checking the amplifying transistor and its command.
Posted on Aug 25, 2010
  • 3,866 Answers
Might need a new wheel on this I have seen this happend ot these before, if your shure it has plenty of ink then you know your going to need to have the wheel replaced.
Let me know do not be a stranger feel free to ask!
Accept button only if your satisfied, We are here to help, Ask me a question with reply to expert. Seek second opinion only if i am DEAD wrong.
  • Grand Canyon Tech
    Grand Canyon Tech Aug 25, 2010
    Wiow
    you never explained to me what was not moving in the cheif complaint but was more then willing to reject my answer and provide more of a diagnosis to your problem ot another expert.
    if that part is not moving or stirking the wheel then you going to need that whole kit, Lexmark would be able to service this a little batter then we can over email.
    I expected more information form you tho before getting rejected, but that is okay
    I ma sure the other expert will confirm your findings
  • Grand Canyon Tech
    Here is the kit you need
    http://www.bizrate.com/miscellaneous-off...
    Thsi s a IBM lexmark type wirter and the kit is about 80 bucks
    its all one unit,
    Thanks
    The accpet button if you find this new info helpful
Cutting of bottom of letters
Really, you have a typewriter?
You stop typing before you reach the end. If it is the electronic type with a display, you need to set the paper size to the size of paper you are using.
If you are using a computer and word processing program, again, set the paper size.
Oct 01, 2015 | Office Equipment & Supplies
Hammer won't strike
1.If your unit is not printing check the ribbon cartridge to make sure it has not run out.
2.If the ribbon appears silver or gray install a new cartridge. Also make sure the ribbon is advancing in the cartridge.
3.Next make sure the black lever in the center of the carriage is pressed toward the paper. If not, press the black lever toward the paper to lock the daisywheel into place and reset unit by holding down the "CODE" key, while holding the code key down press the "REST / Q" keyand release both keys.
4. Try typing. If problem still exists contact an Authorized Brother service center. You may do so at 1-800-284-4357 or by visiting our website.
Apr 22, 2013 | Brother GX-6750 Typewriter
Ribbon does not advance properly to give clear imprint
You are in the over strike ribbon mode. The code and period, comma or slash (I can never remember which) will get you out of the mode.
DickyO
Sep 04, 2012 | Olympia Standard 300 Typewriter
When typing, the letters are not showing up well unless it is on double strike. have take printwheel out and changed ribbon but still not striking paper well.
The problem may be the ribbon or the media you are typing on. try typing on a mulit part form, if the copies are good then its the ribbon (OLD) or the paper (GLOSSY).
DickyO
May 06, 2011 | Brother ML-100 Typewriter
I have a Canon StarWriter 30 that I bought ~1995. I rarely use it, and have kept it in mint condition. I just tried to type something, and found that it's not printing the full characters; it's cutting...
Check that the hammer is striking the letters squarely, that the daisy wheel is firmly located in its holder , Check too that the patten has not moved up in its location. Check that the ribbon can still transfer a deposit across its entire width. (Look back at a used part of the ribbon to see the strike pattern).
Feb 10, 2011 | Office Equipment & Supplies
The hammer on our typewriter won't strike, it just quit in mid type. Any suggestions? When we push a key, it will not strike the letter for it to print on the paper.
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Next clean the main rod that the carriage goes back and forth on, it sometimes get very sticky. Then place a couple of drips of oil on. This should work wonders? Best John ex OEM trained mechanic
Dec 22, 2010 | Brother SX-4000 Typewriter
Cant get the typewriter to print
Be sure the the ribbon has not run out or is jammed. You can test this by rotating the colored knob on the top of the ribbon cartridge in the direction of the arrow imprinted the housing.
If not, do you hear the click of the hammer striking the printwheel? If not you may have a defective main board or hammer solenoid.
Apr 18, 2009 | Brother GX-6750 Typewriter
Keys are striking the paper but no black ink is printing on paper
If tou put in a two part form and it types on the second form the ribbon is either empty of not lifting up. If it isn't lifting up there is a large black gear on the rt. side of the printer, wiggle it back and forth they sometimes jam tooth for tooth.
DickyO
Dec 19, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Sep 22, 2008 | Lexmark Wheelwriter 3 Typewriter
Nakajima AE710 typewriter
The forms obviously have a glossy surface, a fabric or multi strike ribbon will work. There is a impression control oh the l. side of the keyboard and also a bold feature, try max impression and bold.
DickyO
Mar 27, 2008 | Nakajima AE-740 Typewriter
Lexmark Wheelwriter 6 Series II Typewriter Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
