Question about Dell Inspiron 6000 Notebook
How do I repair a damaged hardware device (DVD+RW)?
I get a message, saying this:
"Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)"
I lost my installation CD somehow ever since moving around a lot from in 2005 since Hurricane Katrina. Is there a possible way I can fix this WITHOUT the installation CD? I don't have the money to RE-install it. I have a 2 1/2-yr. old Dell Inspiron 6000 with Windows XP. Is there any way to retrieve it? & was this possibly caused by a virus?
& also, I went to the help section of my computer, & it said that my (D:\) drive device is BLOCKED. What does that mean? How do I UNblock it? I have this work saved on my hard drive. I put it in a new, seperate folder on the hard drive on the desktop location. How can I bring back my D: drive without losing my saved work? How can I back up these files if I'm missing my D: drive? I tried to restore my system 32, & it wouldn't let me. Then, the computer told me to erase all restoration points & turn off the SYSTEM RESTORE feature & then turn it back on to get the DVD+RW drive operable again. But it didn't work. So, yes I cleared the restoration points, but it's still telling me that I can't restore my computer. So, the drive is damaged/corrupted.
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 06, 2008
  • Dell Master
  • 5,568 Answers
Unless your system is configured unlike most, the D:/ drive is a partition, not another physical drive and is (in most cases) only conditionally accessible since it often contains a backup of the system software and your settings but not documents.
If those instructions were really from Windows, this may be because of an infection that has also been backed up and will be restored along with legitimate files.
Obviously, once the sys, restore files have been demolished, you cannot restore to an 'earlier time.'
I do think you are infected and you will likely have to buy a anti-virus package (no download) to get enough access to reinstall system files.
If the 'installation CD' you lost was from Dell, you can order one by phone or on line at some nominal cost.
Have your serial number and complete system model number on hand before you contact them.
As far as your personal document files are concerned, they may be lost forever if you have not kept them backed up on optical disks or external drive.
Posted on May 05, 2008
My cd driver isnt working and device manager says: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) have an hp probook...
Most cd/dvd's don;t use a driver they rely on a atapi common driver. Usually when you get problems it means the drive itself is the issue. For now what I would try is simply to go under /control panel hardware manager and delete the drive then reboot. Windows will detect the drive and should re-install the device information and correct the registry.
Sep 12, 2011 | HEWLETT-PACKARD ProBook 4520s
Code 19- philips cdrw/cvd scb5265 ata device how do i fix it
Do you receive the following error message?
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19)
Code 19 is a common error message, your computer sends because NERO, Roxio, and similar CD/DVD recording software and also and update for Windows VISTA (KB938194) is causing issues. It can create problems with your sound as well.
Even if you uninstall these it will not resolve the issue, because these programs leave the problem inside your registry.
What is happening to your computer?
Device Manager sees the drive, but you get the yellow exclamation mark and it indicates "Your registry might be corrupted. (Code 19)"
How most people try to fix this error – and you are probably doing the same - without any luck…
If you try to uninstall the device and the driver and read new hardware - no change.
You can try to update the driver and the wizard will say there is no better driver found for the hardware.
You can try to run the install CD (copied it to a flash card and ran it from a flash card reader since you can't run it on the DVD drive) - same problem will occur.
You can't do a repair install of Windows since it is on CD and it won't boot properly from the drive.
You can try to use an external DVD writer (HP dc5000) through the USB port and it will get the same code19 error.
Even if you try manually copy the drivers listed in driver details for the device - no luck
Jun 14, 2010 | Samsung Philips CD-RW Kit 4x4x32 ( CDRW...
DVD, CD no longer works. I get the following
Go here: http://support.microsoft.com/kb/314060
Download the FIXIT tool (icon in middle of page) and run it. Then reboot your computer and Windows will re-detect and install any CD/DVD drive in your system.
If this does not fix it the drive probably needs to be replaced.
Mar 21, 2010 | Computers & Internet
DVD-RW does not work and is not recognized. It does show up in device manager but the device status lists the following error: Windows cannot start this hardware device because its configuration...
Download and run a registry scan with ccleaner from here.
http://www.filehippo.com/download_ccleaner/
This will remove the corrupt registry entries. You will need to restart your PC afterwards and may get the "new hardware installed" message.
Dec 23, 2009 | Toshiba Satellite A215-S4747 Notebook
E DRIVE DISAPPEARED FROM LAPTOP (ACER)
this is a known issue check the microsoft website on how to work on this,. look for the part where you need to do something with your registry.
Dec 18, 2008 | Computers & Internet
Sony dvd rw dw-g120a
I cannot burn my home movies to my dvd drive, my dvd drive is called SONY DVD RW-G120A, it says this device is disabled Code 22, Please help me fix this problems. Thank you
Oct 15, 2008 | Sony DW-G120A DVD RW Dual Layer Burner
Dvd rw or cd-r/rw not being reconized by computor
Uninstall the drive via Device Manager, restart your system and let Windows install it.
Update to the latest Windows Service Pack.
Download the most up-to-date Chipset drivers.
If none of these work, clean your registry.
http://onecare.live.com/site/en-us/default.htm
This is free, and will fix. Choose Clean Up if you have XP, or choose Beta version if you have Vista.
Hope these solve your problem
Regards,
Tim
Aug 11, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Error Messages
CAN I CHEQ THE THE WARRANTY?
Nov 17, 2006 | LG (GSA-4167B) DVD RW Dual Layer Burner
Dell Inspiron 6000 Notebook Logo
73 people viewed this question
Alun Cox
