Question about Euro-Pro Shark SC710L Handheld Steam Cleaner
I have a SC 500 hand held steam cleaner and cannot remove the cap to put water in. I've released all pressure and it's still stuck.
SOURCE: scunci steam cleaner not spraying steam
I had the same problem with the 1600 Scunci Floor model...It seems that steamers are prong to calcium deposits. This is especially true if you have hard water. I tried everything....I even opened the unit up...I don't suggest you do that but you can fix the problem by buying a new hose...just google Scunci Accessories....I actually got my working but I don't trust my home made remedy....I'm just gonna buy a new hose....I learned also that you should put CLR and vinegar in the steamer before each use to avoid the calcium deposits.
Posted on Jun 12, 2008
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
  • 29 Answers
SOURCE: Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
Posted on May 29, 2009
  • 92 Answers
SOURCE: Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Posted on Jul 29, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
My Euro-Pro leaks steam at the filler cap. It is tightened down but still leaks. Have replaced the rubber ring in the cap but still leaks dangerous pressure steam.
take cap off remove gasket get clr calcium lime rust cleaner put cap in cup of clr give it 4 or 5 min remove rinse replace gasket, empty tank fill with distilled water not tap water no from now on use distilled water only.
Oct 18, 2014 | Vacuums
My Shark hand held steam cleaner sc 505 is not building up pressure, steam is leaking from lid
Throw it out, get a hoover floormate, best machine I ever had. My Shark steam/vac now resides at the dump after steam clogging problems and not being able to remove the hose to blow it clear.
Mar 17, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam blaster jr. makes steam but has no pressure
yes no vinegar please. Try a product called scale clean or tablets for de-scaling coffee machines. Available from coffee machine retailers
Sep 19, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Sep 09, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Can't get the top unscrewed
I had the same problem. Mine had been stored for a year. We had to completely destroy the plastic cap. Once down to the metal underneath we did the boiling water thing. It didn't work at first so we tried it again. And then immediately after applying the boiling water we used ice water to make the metal contract. With pliers on the neck and pliers on the lid we were able to open it. But, I know my husband had to put some strength into it. Hope this helps you all!!!
sorcha1580
Nov 16, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
Oct 24, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
No steam coming out
The fall might have damaged or moved the trigger so that it does not depress the valve on boiler.
Try removing the screws which hold the handle together. The cap needs to be removed to allow the handle to separate.
Once the handle is apart check the trigger piece looking for any broken parts.
Jul 07, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Euro-Pro Shark SC710L Handheld Steam Cleaner Logo
88 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
