SHADOW LINES VERTICAL ON SCREEN - Televison & Video
    President:
  • 2,712 Answers
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Black shadow on screentnfmurtagh
my new one month acer aspire laptop lcd screen become white vertical flash lines
Jun 15, 2011 | Philips 32PF5531D 32 in. LCD Television
Verticle lines appearing near top. Reminiscent of more extensive problem a few years ago that repair man said were related to electronic equipment used nearby such as vacuum cleaner. He fixed it with...
Case 1:
If the horizontal lines are red, green or blue or white, and are slanted about 15 degrees up going left to right, they are "vertical retrace" lines. These are caused by the beam current in the offending gun being left on while the vertical deflection is retracing from the bottom to the top on its way to start drawing the next frame. The usual cause is the CRT screen setting being too high (too bright), but (rarely) it could be something wrong with the vertical blanking circuit. Since it is dependent on vertical position, I would check the power supplies feeding the vertical deflection circuit and the CRT bias voltages, especially if they share the same filter capacitor.
Case 2:
If the lines are true horizontal, and colored similarly to the picture (sometimes alternately white and colored the same as program material), the top of picture is folded over itself because of over-voltage distortion ("clipping") in the vertical drive. In this case, reducing the height of the picture also reduces the fraction of the picture with the lines, and may eliminate it. If you are unable to get a full-height picture without the lines, then you should check the vertical deflection circuit for leaky capacitors (also check the power supply voltage going to it).
Case 3:
Several times I've observed bright white lines with random interruptions at the top of a picture supplied by the local cable company. These often occur on one or a few channels for a time (once or twice I've seen it on all channels), and go away after a while. This is a glitch in the cable service.
Case 4
You have a zone of weird colors at the top of the screen. This is probably caused by magnetization of the shadow mask inside the front of the picture tube that is not being erased when the TV is first turned on. Check to see if somebody left a magnetized object on top of or above the TV (look behind the set also). If you find something remove it, turn off the TV, wait a few minutes, then turn it on again. (Explanation: the TV has an internal demagnetizing coil that operates only when you first turn it on. It uses a self-heating temperature-dependent part to gradually reduce the alternating current going through it to override and "fade out" any stray magnetism in the shadow mask.) If the internal demagnetizing (AKA degaussing) coil isn't strong enough, you'll need that "ghostbuster" gadget again. If you don't find an external magnetic source, the internal coil may have slipped out of place at the top of the picture tube and is too far away from the shadow mask, or something is wrong with the degaussing circuit.
If none of these cases match what you see, try a more detailed description of the lines and I'll give it another shot.
Nov 27, 2010 | Sony Televison & Video
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Shadow on everything.
Is it mostly one color? Most likely the light engine is at fault and will require a technician to replace it.
Aug 15, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Vertical shadow on screen
check the vertical transistor or bouton.
Nov 16, 2008 | Philips Magnavox 42MF521D/37 Television
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Televison & Video Logo
390 people viewed this question
Top Televison & Video Experts
