Question about Timex 27191 Wristwatch
Can not open the band to put it on
Help!
Take a thin bladed knife and slide it between the watch strap and the buckle part of the watch body. The pin which holds the strap to the watch is spring loaded like a toilet roll spindle. Very gently twist the knife blade to release the pin from the body.
Be warned, getting the pin back into the watch can be very fiddly.
Posted on May 20, 2008
Need a better closure on my Navajo wrist band
I would need to know what the width of the band (at the watch case) is, and a photo or two would help so I can see just what has and has not worked for you. If you want, you can email me: chiefo@wbcable.net
Mar 28, 2017 | Watches
I want to change the watch strap, mine is brokem
Probably don't need special order band. Most people buy band that is same width. Bands have a collapsible post on each side where they attach to the watch, you just pick a band that fits the width. To change a watch band you have to use something like a razor blade (single edge common to cleaning) to wedge between the metal frame of the watch and the band, then try to get some friction on the post and push it away from the watch and toward the middle of band such that you collapse the post and get it out of one hole that the post is in (2 holes 1 on each side of post) so you can tilt the post out. A new band usually has 2 posts included since it is common to bend the old posts getting them out and hard to just buy those. Put the post in the band, put one end of post into a hole, then tilt and compress with the razor to push post into position, then slide the razor out which allows it to go in the second hole. Now band stays attached.
Jan 10, 2012 | Adidas Adistar ADP1786 WW Watch for Men
My daughter got the watch as a gift, and we can't get it open for her to put her hand through it. Is there a specific catch or trick to opening the band and make it work? Thanks.
I need to know what model/brand the watch is.
check the sides of the clasp if there is a button. Sometimes it might just be tight and needs a good pull
Feb 28, 2011 | Watches
Replacement watch band for freestyle macdaddy
If you go to http://www.genevawatchgroup.com/ and click on "other brands", you will see that they make Freestyle watches.
They do not list watch bands here but you can contact them for help.
May 15, 2010 | Freestyle MacDaddy Orange - Diameters 44 x...
How to shorten watchband
It all depends on the style of the band.
Go to where the links are all the same size, not tapered at all.
If you have a stretch band, along the edge, unbend the flaps that hold what look liks tiny staples. Pull out what you need removed and put the remailing pieces together.
If you have a non-stretch band, grab a SMALL paperclip about 1/8" from the end. Along the edge of the band you will see the pins that hold it together. Have someone hold the band with the bottom edge of the pin you are removing, over an opening. Between 2 hardback books wirks great. Tap the pliers to drive the pin partially out. Pull it out and do the same to remove as many links as needed. Put the pins back in, in the same direction they came out, from the same side they came out.
Dec 28, 2009 | Seiko Watches
How do i remove a link from the watch band?
hi friend,
step 1
Measure the watch band's length. Every wrist size is different, and there's no need to remove all of the links when you may only need to remove one or two. Putting the watch around your wrist and pinching each link around it to see how much room you need gives the jewelry wearer a reasonable estimate.
  • Step 258782_65x95_aspect.jpg Open the watch near the link you want to remove. Link watches have several openings, so even if you open the wrong clasp, it can always be reattached.
  • Step 358783_65x95_aspect.jpg Flick the tip of your fingernail inside the clasp to open the extra links. Continue doing so until you have removed all of the links that are too big for your wrist. If you have short fingernails, try using tweezers or anything with a sharp edge that can easily unfasten a link. New watches tend to be very stiff, so it may take a little nudging, but the links come off. It will be obvious which ones come off and which ones don't by looking at the back of the watch band. The links that come off have a claw on the tip of each one and sometimes have the brand name on top of it.
  • Step 458784_65x95_aspect.jpg Put the extra links in a safe place. There may come a time that you either let someone else borrow the watch or your wrist swells and you need these links again.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If you can't get the links to open, visit a jewelry repair store. Workers there may be willing to help you adjust your watch for free. If you bought the watch from a retail store, the jewelry counter is usually required to adjust your watch for no additional cost.
    hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Kenneth Cole Reaction KC3367 Wrist Watch...
    I need help
    It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
    i
    Aug 13, 2008 | Movado 0604586 Wrist Watch
    How do you replace the watch band on a casio g-shock
    The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
    If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
    Band = Strap
    You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
    If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
    The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
    In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
    Jul 20, 2008 | Casio Watches
    I cant open my brand new watch ...HELPPPPPPPPPPPPPPP!
    I just recieved a Moldavo Men's Junior Sport (Model # 0605105 with certificate of authenticity) as an award -- but the instructions didn't bother explaining how to put the watch on!
    For any hidden clasp band, see this web page (excerpt below):
    http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
    Refer to the "Hidden Clasp" diagram and follow the instructions under the diagram:
    cad9c3e.jpg To open this clasp, reach under the bracelet band and lift upwards. The band extends to allow for easy removal.
    Jan 09, 2008 | Movado Kardelo 0605479 Wrist Watch
    How to open a ladies rolex watch band
    how to open rolex wrist band brand new watch
    Oct 03, 2007 | Watches
    Timex 27191 Wristwatch Logo
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    David Ellis Rhea
    Are you a Timex Watch Expert? Answer questions, earn points and help others
