Question about Coleman Mach III Air Conditioner
My colman rooftop ac unit shuts off after 5 min of use wait 5 more and you can turn it back on again when its running it works great its on a 1984 holiday rambler and has very low hours?
  • 33 Answers
Try a new fan motor. It runs about $125.00, It will run a few min. then will trip the motor themal switch. you can probably still here the compressor running. It may also trip the breaker on shore power . good luck! the part you are looking for is a 1/3 hp 115vac 2 speed 1580/1020 rpm part number #1468-3069
Posted on Aug 30, 2010
Rv a/c is off but every 5 min it turns on runs for 1 min then turns off. is this short cycling? the tstat is off. there is no call for a/c. ???
SOMTHING IS TELLING THE AC TO COME ON POSSIBLE SHORT ALSO YES IF UNIT IS COMING ON THEN SHUTTING OFF ITS SHORT CYCLEING (SHORT OF FREON)
Oct 07, 2013 | Dometic Rooftop RV Air Conditioner
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Sep 07, 2010 | Coleman Mach III Air Conditioner
Shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
May 17, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
Throwing breaker
Throwing the MAIN BREAKER should not happen. Calculate the distance to your main box. Tell me the wire gauge or breaker amperage. Whatever you do, do not get a larger breaker! If its a breaker on this unit Its probably doa with current leak possibly. DO NOT USE fire hazzard IF SHE TRIPS!!! let me know if its your main breaker inthe house. Hopefully you dont have crappy cloth wiring.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
235 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
