Question about Honeywell Heating & Cooling
My lines are freezing and the ac works sometimes and sometimes it doesnt. How do I avoid the lines from freezing
  • 139 Answers
Always keep clean filters /low air flow across the coil will make it freeze /if it is colder outside at night than inside will make it freeze up /if the unit runs for to long without cycle ing off/ at low outside temps the coil will continue to freeze .so you can either switch fan to on so the fan continues to run to defrost the coil / if its froze up between on an off cycles or the unit could be low on refrigerant this also will cause the coil to freeze ..hope this helps ..good luck/joe/
Posted on Aug 26, 2010
    Problem Solver:
  • 28 Answers
You need to check your filter to start with if thats good make sure all you vents are open and your returns are free from abstruction
My yaris 2007 car ac stopped working before 2 months slowly , means sometimes work and some times doesnt work , and not at all . before 2 weeks i showed 2 car ac tachnicians both told to change control...
The best I can tell u is that the smell is from a leak at the evaporator or connections. I advise to get another opinion because it sounds like a lot of guesswork. if u get the work done, make sure the work comes with a warrantee! I gave all my customers warrantees for 20 years. That's part of the diagnostic business! Good Luck If u don't get a warrantee ,don't get the diagnosis or work done
Mar 25, 2017 | AC Cars & Trucks
My ac works good and sometimes it doesn't work at all.
They won't work when over charge. Over charging it will freeze up the lines. It will work at first until the lines freeze up. Most likely you have a clogged or malfunctioning expansion valve. On the passenger side, mounted to the fire wall. A rectangular block.
Aug 31, 2015 | 2002 Chevrolet TrailBlazer
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
Water line freezing in door of GSL22JFXJLB Side by Side
the problem is the line is freezing up due to obstruction or blockage. which causes the water to back up and freeze, I have used a blow dryer, hot water, and a soft type long tiny tube or cord like material and even a coat hanger but be very careful, to get inside the line and unplug the obstruction or if u can remove the whole line and replace it? but may be very difficult. why was it pluged? some times pc's of plastic bags, old food particles, etc get into the line, doesnt take much
Mar 11, 2015 | GE Refrigerators
My honda prelude 1992 s the air con doesnt always work! like sometimes ill press it in and the light will come on on the aircon button but mostly it doesnt! the aircon only sometimes comes out cool i think...
need to check the back side of the ac connector where the harness plugs in remove the heater control unit assy and u will see the ac button connector with it still pluged in start the car and turn the ac button on wiggle the ac connector if the light comes on and off it's a loose connection in the harness/connector at the ac button try to jamb a folded over zip tie about 4inches long in between the ac button connector and the plastic frame basicly just make sure that the connector staitionary not wiggling around I had the same problem on my 95 prelude vtec push the ac button sometimes comes on or hitting the dash just got old hope this helps
Sep 30, 2009 | 1992 Honda Prelude
I have a Macallister Hammer drill Cod 144vchd and the hammer action is not working - cannot get the cheuck to line up with the hammer symbol
The chuck may be frozen, try applying some oil inside it. If that doesn't work it will need to be opened and inspected for any damage or frozen gears. You always want to rotate the settings every so often to avoid something like this happening. The metal gears sometimes freeze/seize after being in one place too long.
Aug 28, 2009 | Drills
AC Works Intermittently
could be low on freon more than likely
Jul 28, 2009 | 1995 Chrysler LHS
Toshiba Satellite temperature related freeze
hum that could be right to avoid wasting money, please get a new board, but if u can get a processor and ram to test with, u might be lucky, right
Jul 17, 2009 | Toshiba Satellite (K000004080) Motherboard
Ac compressort had to be replaced because it seized up. AC ran good for 2 weeks then went out, now the heater doesnt want to work half the time. i dont know if its my heater coil, a leak in my ac lines,...
THE BLEND DOOR THAT CONTROLS HOT TO COLD SWITCHING IS STICKING. THE CONTORL HEAD IS ELECTRIC AND MAY BE CAUSING THE PROBLEM. HEAT AND AC ARE 2 COMPLETELY DIFFERENT SYSTEMS EXCEPT FOR THE CONTROLLER UNDER YOUR RADIO. HEATER COIL IS REALLY A HEATER CORE WHICH IS A LITTLE RADIATOR INSIDE THE CAR BEHIND THE DASHBOARD.
Mar 22, 2009 | 2004 Dodge Intrepid
Heating & Cooling Logo
218 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
