Question about NEC MultiSync LT280 LCD Projector
Projector is mounted on the ceiling and display is upside down. how do I fix this?
Go to the setup menu and change the orientation. You will have a number of choices. ex. Ceiling front, ceiling rear. Select the position that the projector is mounted and the picture will reorient and display correctly.
Posted on Mar 23, 2011
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How can i flip the screen up side down on the projecter
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
I mounted my In Focus Projector upside down because of the ceiling mount I bought for it. Now the picture is upside down. How do I fix this?
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
Sep 28, 2009 | NEC VT465 Multimedia Projector
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Feb 22, 2009 | ViewSonic PJ513DB Projector
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Need to invert the picture--ceiling mounted
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Aug 19, 2008 | InFocus ScreenPlay 4805 Multimedia...
NEC MultiSync LT280 LCD Projector Logo
163 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
