Question about Refrigerators
I have no water coming out of the door. - Refrigerators
  • tarorke Aug 25, 2010
    The holding tank inside the fridge is full and the ice maker is working. Is there a seperate pump to draw water from the tank or is it forced out from the main pump?
    Todd
  • 857 Answers
There is a water valve(inlet) that is responsible for the flow of water to the dispenser and ice maker(if equipped). i recommend testing the operational value of this valve.((Make sure the lines are not frozen before testing. frozen lines will affect the flow also))
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Aug 26, 2010
  • Refrigerators Master
  • 3,083 Answers
There is a water inlet valve that comes in the back of most refrigerators, and it could be bad. Read this blog about this problem:
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/19395-maytag-mzd2667hes-water-dispenser-problem.html
This page talks about the micro-switch in the door being the culprit:
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/19673-ice-water-dispenser-microswitch-sticking.html
This blog tells how to test the water inlet solenoid:
http://www.applianceblog.com/mainforums/sears-kenmore/14904-testing-ice-maker-water-supply-solenoid.html
Might be the door micro-switch, so check that out first.
If you google your make and model number, you might be able to find a site that describes the exact model and has diagrams to assist you.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 25, 2010
Door water dispenser not working
It may be the water line in the door is frozen. I have come across this several times. Check to see if the water is coming to the door by disconnecting the quick connector to the door behind the grill at the base of the refrigerator. If water comes out of the tube there then you will have to defrost the freezer door by leaving the door open for a coule hours.
Mar 22, 2014 | GE PSS26MGPBB Side by Side Refrigerator
New water filter, water coming out of door, but not coming through filter
If water is coming out of the door, then it is passing through the filter successfully. It is possible that you received a faulty filter if the door water does not seem filtered. For new filters, visit https://www.freshwatersystems.com/s-2-replacement-water-filters.aspx.
Dec 16, 2012 | Whirlpool Refrigerators
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
May 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
No water d from door, although ice maker works fine . i shut water off in townhouse and trun ocemaker off when we leave. when we retur, i turn water back on and ice maker works but water does not come from...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Jan 08, 2010 | GE Refrigerators
Water in door is not coming out very much intermiient
There is a mesh screen filter in the water supply line where it connects to the water inlet valve on the back of the unit. You can disconnect the line coming out of the valve and try the dispenser to see if it comes out normal. You can disconnect it at the bottom of the freezer door to see if it comes out normal there. If it does the water could be freezing in the door. Leave the door open till it thaws out. Cover the freezer with a blanket to prevent loosing too much cold air.
If you have a water filter it could need changing.
Nov 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water in door suddly quite. have replaced the water filter but still notthing
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Nov 03, 2009 | Maytag Refrigerators
Water in door too slow coming out
A strainer before the inlet valve can get stopped up restricting flow. It's on the back where the water supply connects.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 20, 2009 | Refrigerators
Side by Side refrigerator water does not come out. Replaced filter and still does not come out. Light, Ice and crushed out work.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water comes out here
Aug 20, 2009 | Refrigerators
No water going into door for dispensing or ice maker mod# MRS26LJ
I'm not sure what you damaged with heat but- Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws OR
Aug 08, 2009 | Frigidaire FRS26H5AS Side by Side...
Water coming from under door
  The water line enters door thru lower hinge.  Check the connection by door hinge.  Remove toeplate to access this.
Oct 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
