Question about Microsoft Standard Wireless Optical Mouse
After installing new batteries, mouse is completely unresponsive
    Sergeant:
  • 223 Answers
You need to pair the mouse with the base via the connect button located on the base unit and under the mouse, this needs to be done in the right order, after connecting the unit to your pc while running windows. not before you boot up. cheers
Posted on Aug 25, 2010
Keyboard and track pad are not working, completely unresponsive.
Try and external keyboard and mouse. If they work then re-install keyboard and mouse drivers by removing then first and let the OS do it.
If this doesn't work your pc might be infected. Try to clean it or save data and re-install OS, that is if the external keyboard and mouse work. If not then it is a hardware problem.
Apr 03, 2014 | HP ProBook Computers & Internet
Laptop screen frozen;arrow wont move;cant type in user name.ACER Aspire
The appeal to any laptop is the ease of portability of the machine, and an Acer laptop is no different. With an integrated mouse pad, these computers can be quite the boon to those looking to have their technology on the go, but a number of issues can afflict Acer laptops, including unresponsive mouse pads. Fortunately, a few clicks of the keyboard and some driver downloads can alleviate most Acer mouse pad problems.
Take a close look at the Acer laptop mouse buttons. Make sure the exterior of the buttons are clean and that there is no grime around the edges and crevasses of the Acer buttons. Dirt on top of the mouse pad can result in slower performance or an unresponsive experience, while grime around the sides of the mouse buttons can cause problems with the pressing and depressing of the mouse. Is there any way your mouse pad has been turned off? Check into this possibility. On an Acer laptop, hitting the "Function" (Fn) key and "F7" on the key board will result in the mouse pad being switched off. Hence, you may have hit this function and your mouse pad may not actually be broken or require any repair. Hitting the "Fn" button and the "F8" key on the Acer keyboard will result in the mouse pad being turned back on again. Click on the "Printers and Other Hardware" option on your PC. This is an alternative method to the above. At this point, examine the menu that comes up and click on the button at the top that reads "Device Settings." You should then see an option to click on your Acer mousepad. Highlight this option and click "OK." Launch your Web browser and go to the official Acer website. http://www.acerpanam.com/ The above steps may not have worked, so downloading new drivers for your mouse may be necessary. Select your country of origin, then click on "Support." You will be asked to click on your country again. After you do so, click on the link that says "Drivers and Downloads" on the left sidebar. Select your product line ("Notebooks") as well as your specific Acer computer model, and then hit "Search." Click on the link that says "Touchpad drivers." Your Acer computer may only require new drivers for your mousepad. Download the .exe file and run it to install the contents to your Acer computer. Restart your Acer computer after fully completing the download and installation process. Once the restart process has completed, the driver installation will be complete and your mouse should work again.
b>
Feb 06, 2013 | Acer Aspire Computers & Internet
I have an Asus 1201N netbook and my mouse stopped working. Windows starts correctly and I can navigate through the Windows 7 Start panel with my keyboard but the mouse does not respond. What am I to...
Don't think it could be a mouse driver problem since you already said that it stopped working which meant that the mouse was in fact working before under Windows 7 on your netbook. Based on this, here are some suggestions to resolve your unresponsive mouse problem. Basically, you are trying to determine if the problem is due to the mouse or due to the netbook....
1. If you have a wireless mouse, did you try replacing its battery with a new battery?
If the wireless mouse now works with the new battery, your problem is resolved.
2. If you have another laptop, did you try moving the unresponsive mouse to try it there?
If the mouse also does not work on the other laptop, then suspect the mouse is faulty.
3. If you have another mouse, preferably a wired one, did you try it on your Asus 1201N?
If the replacement mouse works on the Asus 1201N, then suspect original mouse is faulty.
4. Finally, just an observartion, the Windows 7 mouse driver expects a Microsoft mouse and if you click on Control Panel > Mouse, the Mouse Properties window will say No Microsoft USB Mouse Detected but this should not prevent the use of any generic mouse.
Mar 28, 2011 | ASUS Eee PC 1000HE Netbook
I purchased a new Belkin wireless mouse and it worked a few times but not is unresponsive. Help.
press both the reset button of the wireless mouse and the receiver. also check the batteries
Mar 28, 2010 | Belkin Wireless Keyboard/Optical Mouse...
Non functioning left button on mouse pad replace or repair?
Take a close look at the mouse buttons. Make sure the exterior of the buttons are clean and that there is no grime around the edges and crevasses of the buttons. Dirt on top of the mouse pad can result in slower performance or an unresponsive experience, while grime around the sides of the mouse buttons can cause problems with the pressing and depressing of the mouse.
Launch your Web browser and go to the official manufacturers website. The above steps may not have worked, so downloading new drivers for your mouse may be necessary.Update your driver from website.
Restart your computer after fully completing the download and installation process. Once the restart process has completed, the driver installation will be complete and your mouse should work again.
If still it dont work you should first go for repair .
Mar 23, 2010 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Kennsington 72214 mouse is unresponsive in XP Pro
Hello friend,
You must either reconnect your mouse or just install the hardware again all together because some how either your signals are being crossed or blocked.
Mar 06, 2010 | Kensington PocketMouse 72214
I have a kensington wireless mouse. the wireless keyboard works, but the mouse does not. The red laser light is on, but it won't move
Have you tried to resync the mouse with the receiver. Usually,you need to press the button on the reciever first, then quickly hit the button on bottom of the mouse.
Oct 05, 2009 | Kensington Computers & Internet
Cordless v220
Take a look at this web site. Just click the link:
http://www.logitech.com/index.cfm/mice_pointers/mice/devices/3295&cl=us,en
Your battery may be dead.
Software for your mouse listed at this link:
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en?selectedcrid=398&selectedcid=146
I do not have your v220 mouse so I'm unsure if you can replace it with a standard battery. Check it or exchange it from where you bought it.
Good Luck & kind Regards.
& please vote.
Feb 23, 2008 | Logitech Cordless Mouse
Microsoft Standard Wireless Optical Mouse Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
