Question about HP LaserJet 1320n Printer
Black lines on pages - HP LaserJet 1320n Printer
    Sergeant:
  • 223 Answers
Change out the imaging drum. This needs to be done periodically when the image degrades.
typically about a hundred bucks. cheers
Posted on Aug 25, 2010
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
HP LaserJet 1320n Printer Logo
143 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
