Question about IBM NetVista PC Desktop
Netvista PC makes 5 short beeps when it boots, not showing any display
    President:
  • 2,600 Answers
These beeps are very specific to the actual model of the desktop you have. The NetVista had several model of that name and each one used a different motherboard and as well aa different BIOS vendor. In most of the research for this it is evident that either the processor is failing or the motherboard itself has had a failure.
Try resetting the system by powering down the system, remove the power cord from the back of the computer tower, now push the power button to "bleed" off any residual power in the systems capacitors. Now replace the power cord and power the system back up. If you still hear the same boot codes and have no picture, then I would suspect that the failure is with the motherboard. It is very hard to kill a processor if it is secure under the heatsink. It is always possible though that the processor overheated because of dirt, hair etc., blocking the flow of air through the heatsink.
Posted on Aug 25, 2010
    President:
  • 2,666 Answers
Http://www.pchell.com/hardware/beepcodes.shtml
Why does my pc beeps 4 times and will not boot up?
Sounds like you mother board is the problem.
Did you drop it, add memory.......
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
Jun 16, 2014 | IBM Computers & Internet
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
Hello, i have an IBM net vista PC which is using 4 RIMM memory modules of 256Mb each, i removed one of them and later returned in position but from then henceforth my computer cant boot,instead its...
The IBM beep code indicates no power, loose card, or short. Was the computer unplugged when you removed the module? The first thing I would do is remove all modules, blow out any dust in the memory slots, and reinsert all. While you are in there insure any cards, sound, video, are firmly seated.
May 23, 2011 | IBM NetVista PC Desktop
Netvista 6350 lost screen connection after BIOS password reset
If there a separate AGP Video Card in the system? If so, is there also a VGA connector on the motherboard? If you have both, try swapping the screen over to the other one. You may have reset the default video card back to the motherboard.
However, it looks as though you are using onboard video as you appear to be using 256Mb shared RAM for the video memory as your total should be 1536Mb.
In that case, you may need to do a rurther BIOS reset. You can find the complete instructions here
Nov 28, 2009 | IBM NetVista PC Desktop
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Ibm netvista 6792-11u cannot display
Have you tried installing a different video card?
Thanks,
Lee
Jan 21, 2009 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
66 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
