Question about Breville BL1 3Speed Blender
Can I get a replacement blade for the Breville BL1? The white section underneath the blade has cracked - it does still work but leaks liquid out of the bottom into the top of the base making it impossible to clean. Also suspect that germs are hiding within the crack!
3 Suggested Answers
pappapumpdaf
  • 635 Answers
SOURCE: grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Posted on Mar 09, 2010
  • 11800 Answers
SOURCE: Breville BL1 Motor
You would need something like this
http://www.spares2go.co.uk/browse-BREVILLE-bl1-BLADE_KIT_(SEAL_NOT_INCLUDED)-m114-p4026-s9979.htm
Unfortunately your model is an very old one for which the chinese manufacturer no longer makes parts. Try to find the part at repair shops - they might have one , recovered from dismantled units - or just accept that it's dead and buy a new one.
Posted on Oct 31, 2010
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Jul 11, 2012 | Breville BBL600XL. 5-Speed Blender
My breville blender model#bbl600xl leaks every time I put liquid in it, the gasket is in place and it is tightened as much as possible, what is the problem.
It leaks if you over tighten it. So try to just do it finger tight. I was having the same problem, once I eased off on the tighten if stop leaking. I assume you are getting it correctly aligned as that can be the other issue.
May 14, 2011 | Breville BBL600XL. 5-Speed Blender
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
Hello. I need two parts for my Breville Classic BlendMaster Model CBL-10. I need the removable centrally located inner lid and also the blade assembly features patented stainless steel twin cutting...
Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
Jan 23, 2011 | Breville CBL10 BlendMaster Classic Work...
Grease build up around blade and where it attaches to base
Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
Need white base that blade sits on.
I'm going to super glue the crack that is causing mine to leak.
Jul 28, 2009 | Back to Basics Smoothie Elite Work Top...
Lost Seal for Blender
I would suggest you contact the company at
http://www.breville.com.au/ (click on "what's on your mind") and let them know the problem... they should be able to direct you to a UK parts source or help you in some other way.
Mar 23, 2009 | Breville Blenders
Breville 600XL not turning on
My BBL600XL stopped working because of a blown fuse. You need to remove the phillips and torx head screws out of the bottom. Then remove the base. There you will clearly see a fuse on the circuit board.
It appears to be a 10A 250V fuse.
Jan 28, 2009 | Breville BBL600XL. 5-Speed Blender
Breville BL1 3Speed Blender Logo
93 people viewed this question
Top Breville Blenders Experts
Mike
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
