Question about Cobra 29 LTD CB Radio
Static I am getting alot of static. how can i illiminate it??
Move to another location.
Posted on May 07, 2008
My starter will not engage.on my 1992 Honda accord lx wagon.
Standard tranny?,Auto tranny? Possible starter.. No power to starter..Neutral safety switch... Clutch pedal switch. Test starter signal wire power with test light at the starter to illiminate the above. If power available at this wire when key is held in the crank position, the above can be illiminated and a starter is most likely the problem
Dec 26, 2015 | Honda Cars & Trucks
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
CANT CONNECT TO PLAYSTATION NETWORK. SIGNS ME OUT WITH ERROR 8002AD3D. PLEASE HELP
try setting up the ps3 using static ip address.
the subnet mask is usually 255.255.255.0 and check your DNS server in your router to input it in your ps3 cause it can vary.
Next, you can open the ports through your router 80TCP, 443TCP, 5223TCP, 3478UDP, 3479UDP, and 3658UDP all assigned to your ps3 static id address.
You can open the ports or use DMZ function(enable), which is alot easier because all you need to input is the static ip address that was assigned to your ps3.
However, i set them both up and i'm too lazy to go back to check whether it needs both or one of them, but i'm sure one of them will suffice.
Note: If you have DHCP enable, you have to check where the ip address starts and ends. You want to assign your ps3 static ip address within that range. Remember, assign a static ip address that is different from your default router ip address cause it can lead to alot of viruses.
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
Phone line static
with the modem disconnected and the static is still there , indicates a problem service land line
ask your service provider for a line check because of the noise
Nov 22, 2017 | Motorola Mobility MD481SYS Cordless Phone
I need to replace the right bank catalytic converters. What will happen if I dont. Can I just replace them with straight pipes?
you can replace with straight pipe but if you have inspection in your state you may not pass and you may start to get o2 sensor lights on dash
Aug 25, 2009 | 1998 Ford F150 Regular Cab
Inverter faults every 15 - 20 minutes
With out knowing what the error codes are that are being displayed, it is impossible to provide a solution.
Jun 16, 2009 | Inverter KEB COMBIVERT F5
Static problem
Try using a headset or lower the volume.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Apr 11, 2009 | A4tech Viewcam PK335 Webcam
How to set up greeting w/o automated instructions & options
not possible that is a built-in feature on the phone
Dec 24, 2008 | Motorola Mobility RAZR V3
2003 td6 amplifier
Rca's usually or bad ground, power wires,(crossed) (getting static electricity) seems to be alot of stuff going on...
Nov 03, 2008 | Car Audio & Video
GALAXY 88 HIGHT STATIC IN THE RECEIVE ..
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Cobra 29 LTD CB Radio Logo
54 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
