Question about Kyocera Mita KM-5035 Printer
I have aKyocera km-5035 copier. The copier keeps saying please wait image cycle and is making a clicking sound. How can i fix this?
5 Suggested Answers
  • 66 Answers
SOURCE: 0630 Fault code on KM 5035
you have a defective main PCB. you should contact your nearest service agent
Posted on Mar 21, 2009
FixinFax
  • 3085 Answers
SOURCE: Kyocera KM-5035 - I try to change the Developer
After replacing developer unit
press
10871087
scroll up to u130
press print button
let machine run till it stops.
clear
u001
press print button
READY
Posted on Jul 11, 2009
  • 212 Answers
SOURCE: the copier is saying please wait image cycling
pls do following steps
1,take one cross over cable
2,download latest firmware from the website
3,upload the firmware using your pc
4,restart
Posted on Oct 27, 2009
n25an
  • 622 Answers
SOURCE: Kyocera-Mita going offline
it sounds like there is an ip conflict... you may need to reserve an ip address just for the copier or failing that change your copiers ip address to one below the ip range... if it still has problems then I would check the network cables.... and see if you get any error codes... copier can go offline if 1. the print card is loose... bad mounting socket on the main board... ip conflict... someone else has the ip address... poor network traffic... the signals over the network cables are degrading too fast... so the copier gets a corrupt file or unfinished file and bombs out... power surge... this causes firmware corruption and the thing just starts shooting wierd error codes... I think I have given you enough to think about...
Posted on Dec 07, 2009
What does image cycle mean on the KM-5035 - Kyocera Mita KM-3035 All-In-One Laser Printer
you are probably using non Kyocera OEM toner so the machine says image cycle while its trying to add toner you will have to empty all of the toner out of the dv unit put in only Kyocera OEM model specific toner then run dev setup
Mar 18, 2018 | Kyocera Office Equipment & Supplies
Kyocera 5035 scanner c7400
Image formation unit.
Has the drum been removed from this machine.Its either missing or requires replacing
Sep 19, 2013 | Kyocera Mita KM-5035 Printer
Kyocera mita km 5035 image cycle problem
Ensure that the filters are not blocked and that the machine has sufficient air flow around the machine.
Sep 13, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
C7400 error kyocera km 5035
Error C7400 on Kyocera km 5035 is Image formation unit problem or connector
Hope this will help
Feb 14, 2012 | Kyocera Mita KM-5035 Printer
KM 5035 cuts off top of copy image. Text is moved higher on page on copy vs original which cuts off the top of text on copy. Can't seem to figure out how to make it stop doing that. Happens the same...
Hello. Sometimes this can be caused by the duplexing mode being switched on. check the duplexing settings to rectify. Also if the paper position sensor is damaged this error can occur. this required a technician to replace.
I hope this helps Regards GM
May 27, 2011 | Kyocera Mita KM-5035 Printer
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
The copier is saying please wait image cycling
4,restart
Oct 27, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
We have a Kyocera 5035 Copier and getting a message "Page tray is out of order"?? Any ideas on what to do?
if you go into copy mode punch in 1087 1087
press the green start button
punch in 906
press the green button
select the option on the touch screen
and wait until the machine reboots
this should fix any minor problems
Jan 24, 2009 | Kyocera Mita KM-5035 Printer
Kyocera Mita KM-5035 Printer Logo
304 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
