Its getting to hot /either your water level is low in the system /the circulating pump coupler could be broken; so water may not be circulating through the pipes, this will cause relief valve to blow ..air may be in the lines also/let me know if you need more info/good luck/joe/
what does the pressure guage read it should be reading 12lbs at the lowest an 30 at the highest/the relief valve will blow at 32 lbs this depends on how many floors or levels you have ..
