My problem is that every time I use my computer its fine but after a while the volume just drops down on its own and it is not able to stay up once I try to put the volume back up it just drops down again what can it be does anyone have a solution to this? Thanks
    President:
  • 2,291 Answers
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section
1. Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start.
Now next you can do is
If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button.
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner to scan for errors.Download reginout to clean ur system errors ,
Posted on Aug 26, 2010
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I bought a soncm headphones sm-750mv no manual and the volume is low but i got my computer volume 100%.is thre anything i can do/
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar once the icon is in the tasbar you can adjust voleme setting by right click on icon
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jul 06, 2011 | Audio Players & Recorders
My ATP3 suddenly making some noice (Not all the time) when not in use (No audio is playing; but power is ON). During the time of play speaker volume falls into lower level and shift into normal level. ie,...
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 07, 2011 | Altec Lansing ATP 3W Computer Speakers
How do I connect the system?
once you plug your speakers you might have to install them
also
hope this helps
Apr 14, 2011 | Altec Lansing ACS 490 Computer Speakers
I cant use both speaker out in front and rear at the same time. i dont know why?
also
hope this helps
Mar 26, 2011 | ASUS M2V Motherboard
Change the volym
also
hope this helps
don
Mar 01, 2011 | JBL CREATURE II Computer Speakers
Volume won't stay set
There have been many new things that have been introduced when Google bought Youtube, and I believe that one of them is that it resets the computers speaker volume all they way up, the best I can currently suggest is that you leave the computer volume up and turn the physical speaker volume down, and it should be fine.
Hope this has helped,
Ryan Frame
Creative Energy Associates Technical Center
Aug 16, 2009 | Dell 5650 Computer Speakers
Aiwa CXZL 31 volume button seems stuck
all u have to do is turn the volume down once then bang it against the door 5 times...it should be fine...
Jan 04, 2009 | Aiwa Audio Players & Recorders
Vaio laptop volume problem
What version of windows are you runing? If it's pre xp it's probably nothing you are doing, windows's likes to corrupt itself over time. You can bypass your on keyboard volume by right clicking on the speaker icon in your system tray (lower right corner where your clock is) and click open audio properties, everything can be controlled in here. Good Luck
Sep 20, 2007 | Computers & Internet
I need Help!!!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
