Question about Neff Microwave Ovens
When i turn on my microwave it cuts out afer a couple of seconds and displays H 95, john thanks
  • Neff Master
  • 17,129 Answers
Please check your TCO- thermal cut out sensor mounted on the cavity . If this senses a higherr thermal point it might cut off.
Also check on the main capacitor or if the magnetron is faulty.
Helpful?
Posted on Aug 25, 2010
How to change a lightbulb in a model nn-656ba panasonic microwave oven
I may be wrong on this model, but most microwaves need the top/side panels removed to get to the. Light. Afer removing the screws raise the back a couple of inches then slide cover towards the rear in order to slide the top potion out of its retaining clips. They do sometimes get stuck with food etc.
Oct 14, 2014 | Panasonic NN-P794SF Microwave Oven
Display shows "=SE-", and do nothing
"SE" means = sensor error, try to dry it out with a hair dryer, if not working, you have to replace the sensor
Jul 29, 2012 | Samsung SMH9151 Microwave Oven
GE microwave/convection oven 1790 there is a #8 displayed in the right upper corner of display
HELLO.
When the F8 code appears,it means that electric control requires replacement because the relay drive circuit has been lost.
Attempt to clear the code by pressing Cancel and cutting power to the range for 30 seconds.
If the code cannot be cleared, replace the electric control.
thanks.
Sep 21, 2011 | GE JVM1790SK Convection/Microwave Oven
The display window is stating the oven is in "demo mode". We did have a power failure prior to this function happening. What can we do?
I had the same problem after a power cut and eventually thought of switching it off at the mains and turning back on after a couple of seconds... it worked. Just needed to reset the clock and off I went!!! ;-)
Feb 05, 2011 | Panasonic NN-T888S Convection/Microwave...
PANASONIC MICROWAVE-NN-S615BFX
These H codes usually indicate a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Sep 25, 2008 | Panasonic NN-MX26 Microwave Oven
Neff 5474.0/gb. When microwave time and power is set, after pressing the start button,the microwave works for about 2 seconds then stops and the fan starts. the error code H 95 shows on display. The...
After a bit of digging, it appears to be an issue with the door not being closed correctly (or at least the it thinks is isn't.
Ref:http://www.sampfordixl.com.au/gaggenau/upload/BM221130_instr.pdf
I know its a different model but the functionality is identical...
Apr 27, 2008 | Microwave Ovens
Microwave cuts out after 23 secs
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 15, 2007 | Panasonic NN-S550WF Microwave Oven
Display shows nothing, microwave cuts off
You need a couple of cheap microswithes that the door latches hit when you close the door and a new control for your display problem which sharp has had a problem with
Oct 30, 2007 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
228 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
